[ROM] {Gapps Updater} Breadfan
23 replies to this topic
#1 marxman3
marxman3
  • 290 posts
Posted 10 June 2013 - 10:22 AM
As much as I dread two threads, I think it makes sense to have two separate threads so they can be accounted for accordingly. This is based off the Orion ROM. However, it is completely stock (theming, tones, etc.). I have added in the performance and battery tweaks, some ringtones (the default is Breadfan) and a boot animation. All of the nightlies I post will be forked from the Razrqcom Dev team CM10.1 git and I will be using the Vanquish kernel source in the builds.
The AOKP build is forked from the necessary device and vendor branches of the razrqcom source.
The tweaks are in the gapps package (Breadfan). The reason for doing it this way is you can theoretically flash a nighlty everyday there is one (doesn't have to be mine) without losing data.
Thanks and credit to The RazrQcom Dev Team, Bytecode, Hashcode, Dhacker, Sparkyman, Dan Rosenberg, MattlGroff, ForeverKing and everyone else I forgot.....
Nightly (Choose one):
6/18:
6/19:
6/20:
6/21:
6/22:
6/24:
6/25:
6/28:
AOKP
CM10.1
Select Appropriate Base:
Breadfan - CM10.1:
Aokp (Stock Boot Animation):
If you need steps to flash, please read any other ROM thread, flash that ROM, than come back here once you've mastered that.......
If you'd like to donate:
Enjoy!
  • neckchop, jamminjon82, timpohladthomas and 4 others like this
#2 marxman3
marxman3
  • 290 posts
Please keep in mind that nightlies are not a linear progression. Tonight's build isn't necessarily better than last night's build. Some nights the builds won't even compile. The fun is in the finding out which builds are the best (depending what you want - stability, speed, latest options, etc.)
The bugs the ROM will have will be a mirror of that nightly that anyone can build. I encourage you to report bugs, please include the nightly they are from so we all know. Also, I'm not fixing the reported bugs on the nightlies, just compiling the next day and sharing.
  • neckchop, jco23 and jhorton014 like this
#3 marxman3
marxman3
  • 290 posts
Help section:
#4 JayS0ul
JayS0ul
  • 38 posts
  • LocationNJ USA
Posted 16 June 2013 - 08:39 AM
6/16 link isn't working. I've benn trying to find a decent ROM without service issues. Hopefully this is one. Ill let you know what I think in a couple hours.
#5 marxman3
marxman3
  • 290 posts
Posted 16 June 2013 - 09:24 AM
That build didn't boot. Recompiled and reposted in OP
#6 JayS0ul
JayS0ul
  • 38 posts
  • LocationNJ USA
Posted 16 June 2013 - 09:32 AM
OK cool. I found your other thread too which I probably should of checked first. Initially it lags, playing to soon I guess XD
I've thought about getting back into deving, for this phone it seems a little more difficult with all the back door hacks.
#7 jhorton014
jhorton014
  • 10 posts
Posted 19 June 2013 - 07:54 PM
Anyone know how to get the Verizon VVM app to work?
#8 marxman3
marxman3
  • 290 posts
Posted 19 June 2013 - 09:54 PM
Ya use Google voice......
Sent from my XT907 using Xparent Blue Tapatalk 2
#9 romma1
romma1
  • 127 posts
  • Current Device(s):Razr M
Posted 20 June 2013 - 07:26 AM
Intalled 6/20. Now I am adding apps. So far very smooth.
#10 jhorton014
jhorton014
  • 10 posts
Posted 20 June 2013 - 07:41 AM
Thanks.
#11 romma1
romma1
  • 127 posts
Posted 20 June 2013 - 09:01 AM
When I install apps, sometimes it says I am not connected...  am on WIFI. After I try again, i seem to connect and then It starts downloading.
#12 marxman3
marxman3
  • 290 posts
Posted 20 June 2013 - 08:12 PM
IMO the 6.19 & 6.20 builds were not as solid as 6.18. Time to try 6.21
#13 marxman3
marxman3
  • 290 posts
Posted 20 June 2013 - 08:35 PM
6.21 is much better than the previous 2.
  • romma1 likes this
#14 romma1
romma1
  • 127 posts
Posted 21 June 2013 - 07:03 AM
I will try 6/21 at some point I had charging issues off of my computer monitor usb on 6/20... I Love Nightlies!!!!
#15 marxman3
marxman3
  • 290 posts
Posted 21 June 2013 - 09:35 AM
Instead of overlaying the vanquish source, I changed the local manifest to just pull the vanquish source instead of the razrqcom. Makes my life easier. That may cause some issues because commits made by the razrqcom team may incorporate new source kernel commits that bytecode hasn't put into his source yet. I think that was the problem with 6.19 & 6.20. For me the trade off is worth it. I get the latest vanquish source (often the newest source hasn't been released in his thread but it is always fresh in my dailies). Sent from my XT907 using Xparent Blue Tapatalk 2
  • romma1 and jhorton014 like this
#16 jhorton014
jhorton014
  • 10 posts
Posted 21 June 2013 - 01:43 PM
Everything works pretty well except for 2 things. I can't enable Bluetooth and I get some occasional screen tearing. Thanks for your hard work and for making the stock theme. 1 question though. Ids there a difference between the Orion and breadfan besides the theme?
#17 jhorton014
jhorton014
  • 10 posts
Posted 21 June 2013 - 01:50 PM
I forgot. I also can't use voice recognition or vice search. Sorry if I posted this on the wrong thread.
#18 marxman3
marxman3
  • 290 posts
Posted 21 June 2013 - 05:06 PM
I picked up on the voice search not working yesterday. That's a daily bug.
I don't use Bluetooth, but I'd guess that's a build issue as well.
There is a difference between the two. This one is all the latest source (daily and kernel), no build prop tweaks and the aesthetic stuff.
#19 marxman3
marxman3
  • 290 posts
Posted 23 June 2013 - 08:35 PM
Voice search works. 6.24 build seems very solid so far.
#20 marxman3
marxman3
  • 290 posts
Posted 24 June 2013 - 08:19 AM
Will somebody please let me know if bluetooth works properly. It started on boot, but being old Bluetooth isn't something I use.....Thanks
  • shane1 likes this
