Is there a way to make my Maxx more stable?
Posted 11 June 2013 - 11:36 AM
Sent from your mom's bed...
Posted 11 June 2013 - 11:40 AM
Use
utility and flash back to out of the box stock. That will help. Also get rid of the task killer. That may be causing your issues too. It's shutting all this stuff down so it takes way longer to start it back up when you need it- Nanniepoo, Maxximized and jp1044 like this
#3 Guest_BDH_*
Posted 11 June 2013 - 11:41 AM
- The Persuader, Maxximized and jp1044 like this
Posted 11 June 2013 - 11:45 AM
I agree with both things said here. On top of that, I would also install
and set your minfree profile to Aggressive. I have noticed that Blur can mishandle RAM and not leave enough free. Applying that tweak ensures that there will be enough RAM for apps to use when they are launched, which minimizes lag a lot.- Maxximized likes this
Posted 11 June 2013 - 01:32 PM
Posted 12 June 2013 - 02:54 AM
Posted 21 June 2013 - 01:57 AM
Posted 21 June 2013 - 04:08 PM
Posted 22 June 2013 - 11:40 AM
Posted 03 July 2013 - 11:37 AM
Use something other than blur for your launcher. Go Launcher works great for me, much better than blur and more personalization.
How, exactly, do you change launchers? I never knew how to change launchers...
Posted 03 July 2013 - 11:44 AM
Download and install a launcher. When you hit home a pop-up will let you choose which one you want. There is also an app called "Homesmack" that makes it easy to switch between launcher and set a default
Posted 03 July 2013 - 07:53 PM
Posted 04 July 2013 - 08:24 AM
Posted 06 July 2013 - 01:14 PM
Ok, update. Screw GO Launcher. I deleted it and am now using Apex Launcher...its freaking awesome. My phone has sped up a lot and i find it a lot easier to customize...thanks y'all!
Yeah go launcher is relly bloated and sluggish. Looks nice but it performs terrible.
Sent from my DROID RAZR HD using Tapatalk 4 Beta
- The Persuader likes this
Posted 06 July 2013 - 01:56 PM
Next Launcher is the Balzzz...nothing but Net
Its Bubba
"Stubborn In Your Bones"
Posted 12 July 2013 - 08:17 PM
only packs
the bloat but their framework adds a ton of burden on the system. this one
if not the best reason to root
Posted 12 July 2013 - 11:58 PM
Posted 13 July 2013 - 12:00 AM
