I just got my RAZR and rooted and flashed Gummy ROM, unfortunately lack of a camcorder and netflix support is enough to make me go back to Gingerbread. I tried restoring from the backup I made before the flash, but it just sat at a black screen after the Dual Core boot up screen, so I reflashed Gummy. Its working now, but I'm thinking I want to flash to Eclipse ROM until better supported ICS ROMS are out. Is there anything special I need to do to go backwards or is it just like flashing any other ROM?
Going Back To Gingerbread Rom
dsuppa97
, May 03 2012 12:06 PM
4 replies to this topic
Posted 03 May 2012 - 12:06 PM
Posted 03 May 2012 - 01:23 PM
Remember, search is your friend. Use Matt's utility to flash back to .173 then OTA to .181
a what? an android? whats that?
Posted 03 May 2012 - 03:21 PM
Agree. After fastbooting back, factory reset as well and start fresh.
Sent from my DROID RAZR using Xparent Red Tapatalk 2
Posted 04 May 2012 - 03:35 AM
The first ics leak has camcorder as well as netflix. It runs real smooth and minor bugs if any for me. U have to be on the .173 gb rom to flash. Fastboot back data wipe. Make sure if u try this u get the first ics leak, the newest one is causing major problems for those who try to fastboot back to .173 as this is currently not possible. U must b on .173 to flash this, so dont ota to .181. There is a easy to follow step by step with the ability to retain root after the upgrade on the site good luck.
Posted 04 May 2012 - 05:40 AM
I've been on the first I c s leak also going on over a month now. It is very stable a few minor quirks and that's it. Everything works on it the biggest quirk I know this is the screen.... sometimes it requires a double tap of the power button to wake it up...battery life is improved and you can go back to GB...to get on the ota path easily... I did it... I used the dessert we don't speak of here.. worked twice perfectly...
