Earlier today I installed Nova Launcher Free onto my Rage3.2 Razr Maxx.
After familiarizing myself w/the settings for the app, I noted that the drag-down notification bar had skewed colors i.e. I use Widgetsoid & made custom background color theme for all icons in that toolbar. They were black when I created them, but once the prob surfaced, they were plum purple, the icons themselves were colored deep red, & they showed up plum purple when not enabled (Airplane mode) & red when enabled...
I also noticed that the dialog boxes, headers, etc of other apps had similar color corruption.
Then I went into SafeStrap to try deleting the slot for Rage rom & recreate it & then restore fm a nandroid backup I made a couple of days ago; the restore worked, but the dialog boxes Install, Wipe,etc had that purplish tinge inside the other colored line which formed the dialog box for that function.
The default Boot Ani for the Razr has those retracting doors which reveal the 'eye' & they are silver / steel colored; but now they are purplish.
Also, I switched to the Stock side & found the same probs, & even did a Factory reset.... to no avail.
I'm guessing that some color change got written to memory & that stuck & I can't change it & boy, is it ugly!!!!
My feeling is that I should grab Matt's Droid Razr Util for WinAppleLinux, & re-flash...
Any help very much appreciated, my device works, but I wince each time I look at it; & customization is something we rom flashers enjoy, so corrupt color schemes are pretty bad....
TIA,
