Trying To Flash Back From .181 To .173 Using Rsd Lite Error?
Posted 05 May 2012 - 10:16 AM
Posted 05 May 2012 - 10:40 AM
Posted 05 May 2012 - 10:41 AM
Posted 05 May 2012 - 10:47 AM
Posted 05 May 2012 - 11:09 AM
Posted 05 May 2012 - 04:37 PM
Posted 12 May 2012 - 10:26 PM
Posted 15 May 2012 - 05:15 AM
So i am trying to flash back to .173 so i can install the .75 ICS leak. I downloaded all the files and and RSD lite 5.6/Moto Drivers. I then go into Fastboot and RSD does reconize my phone, the problem is when i go to run the file it says failed on 2/23 (which is the first part of the flash). Any ideas
When I tried to flash back to .173 from .75 leak I had the same issue. I found that I forgot to change out the xml file. Once I did that everything was gravy!!!!
You will see: ****IF YOU ARE USING THE 173 FB FILES IN RSD LITE ,TAKE THE XML OUT AND INSERT THIS ONE . THIS WILL LET IT RUN WITHOUT ERROR.*******
You will see the link right above it for the .173 xml file. Hope this helps.
