internal sdcard wipe when have shattered digitizer
Posted 13 June 2013 - 03:22 PM
Posted 13 June 2013 - 04:04 PM
johnthehillbilly is right. One of those drives will be your internal storage. If you remove the sd card, you should have only one drive besides the motocast thing. Format it from windows and you should be good to go.
Posted 13 June 2013 - 05:18 PM
but- I ONLY see the C:\, my d:\ and e\ date drives, and the G motocast
Posted 13 June 2013 - 05:23 PM
Also are you familiar with using adb?
Posted 13 June 2013 - 06:42 PM
screen is toast.
I have adb-, and read the commands online on some web page that had a guide- but i didnt see any wipe, format, etc.
Plus, I dont know how to get adb to see the phone with a busted screen. I did manage to get into fastboot and use opt 1 restore on the 1.82 droid utiltiy from matt.
Posted 13 June 2013 - 06:50 PM
Anyway....using adb is a bit different to do that..... Do you have teamviewer? If so I can "come in" and try to help you out......
Posted 13 June 2013 - 07:03 PM
yeah, i have it- . I still JUST see the G drive, and the PCs drives
Posted 17 June 2013 - 07:37 PM
If whatever johnthehillbilly did with doctordroid.. and i worked.. would you mind sharing? I have the same issue.. shattered screen.. can see nothing.
Posted 17 June 2013 - 07:43 PM
If you have your HDMI cable, you can try plugging it in (to a TV or monitor).... Even with a broken screen you should be able to see an image of the screen..... And possibly manipulate the menus etc.....(depending on how bad the screen is broken)
Posted 17 June 2013 - 07:54 PM
I will have to go grab a cable and try that. thanks.
