Hi
Just got my razr m, upgrading from xt 912.
Wush to use it in India with gsm operators like Vodafone,
On my droid razr xt912 I could just push the sim and get gsm network but on razr m it aint happening, selected gsm only and stuff still not gsm network
Can anyone please help. Would be grateful.
Regards
sent from my NOTE II, yupp size does matter.
How to use vzn razr m internationally with gsm operators
lord dredd
, Jun 18 2013 08:19 AM
3 replies to this topic
Posted 18 June 2013 - 08:19 AM
Posted 18 June 2013 - 10:25 PM
Anyone?
Posted 19 June 2013 - 10:45 AM
Please anyone?
Posted 18 July 2013 - 10:48 AM
the razr m is sim unlocked you can try going into settings under the network and try to change it to gsm from there also get your apn's set for your carrier to if like me you cant find the apn settings there is a free app in the play store that works well it is called Tweakker that should help you
