.84 Governor Question/concern
15 replies to this topic
#1 ncwildcat
ncwildcat
  • 109 posts
Posted 09 May 2012 - 06:25 PM
I have been looking without answer, so I thought I would start a thread to ask about the governor on the leaks. I remember back on gb there was a motplug option. That seems gone in these leaks, instead interactive is the standard. Hotplug is an option but it seems to mess with the screen touch sensitivity. I believe this may be contributing to the lesser battery life some have experienced on the leak
#2 theFix2012
theFix2012
  • 64 posts
Posted 09 May 2012 - 09:52 PM
I'd love to see mot_hotplug on the leaks. It was a solid governor with good battery life. I've asked this before with no answers. I really miss the development that we had on the incredible. You could get answers from devs all the time. I asked for a RAZR devs opinion on this and got nothing. So keep trying i guess.
Sent from the world I call ICE RAZR!
#3 snives
snives
  • 947 posts
Posted 10 May 2012 - 03:27 AM
Before it goes live, I would expect to see Moto HotPlug back. It provided the best battery life with still solid performance because it allowed for 1 core to sleep entirely while the other kept basic tasking running smooth on its own.
#4 (TSON)
(TSON)
  • 529 posts
Posted 10 May 2012 - 04:31 AM
hotplug IS mot_hotplug in ICS. In GB, there was no reason to use hotplug over mot_hotplug, so they just replaced one with the more efficient.
EDIT: And just to let you know, I've been running hotplug since day 1 and I'm having no touch screen issues.
#5 wrich73
wrich73
  • 41 posts
  • Google+:wrich73
Posted 10 May 2012 - 04:39 AM
Hotplug is great! If you are having any issues try switching your scheduler to No Op (noop), seems to give me the best performance and battery life.
#6 ncwildcat
ncwildcat
  • 109 posts
Posted 10 May 2012 - 05:15 AM
What did you use to change it?? Setcpu or something else?
#7 wrich73
wrich73
  • 41 posts
  • Google+:wrich73
Posted 10 May 2012 - 05:18 AM
ROM Toolbox Pro works great
#8 (TSON)
(TSON)
  • 529 posts
Posted 10 May 2012 - 05:29 AM
I use setcpu
#9 BigJArm
BigJArm
  • 212 posts
  • LocationIdaho
Posted 10 May 2012 - 01:57 PM
I'm using Tasker to change mine
#10 ncwildcat
ncwildcat
  • 109 posts
Posted 28 May 2012 - 01:12 PM
I updated to. 206 and it too has interactive set as default governor instead of hotplug.......wierd
#11 tonyo50138
tonyo50138
  • 6 posts
Posted 31 May 2012 - 01:17 PM
how ya set up tasker to do this? thanks :)
#12 BigJArm
BigJArm
  • 212 posts
  • LocationIdaho
Posted 31 May 2012 - 01:31 PM
I set up profiles for screen on, off and on a call. Then the tasks those profiles trigger a task that changes the cpu settings.
The cpu settings are under misc/cpu
#13 tonyo50138
tonyo50138
  • 6 posts
Posted 31 May 2012 - 03:43 PM
What settings do you use under the cpu settings? min and max settings and "theme"
Thanks ;)
#14 Knight Rida 666
Knight Rida 666
Posted 31 May 2012 - 05:02 PM
Anyone else notice battery drains much faster on hotplug than interactive?
#15 BigJArm
BigJArm
  • 212 posts
  • LocationIdaho
Posted 31 May 2012 - 06:42 PM
For screen on 300min 1200 max, screen off 300min 600 max, on call 800 max 300 min
I am using hotplug as the governer.
You have to set each core independently.
  • tonyo50138 likes this
#16 tonyo50138
tonyo50138
  • 6 posts
Posted 01 June 2012 - 03:25 AM
sorry in totally new to tasker, after i create these and turn tasker on and hit the green arrow and it closes and goes up to the status bar, it says no active profiles,
