So changing things up, now its MY turn to ask for help \
EDIT: I can charge it WHILE holding down the power button, but that gets really old and annoying really fast.
Edited by mattlgroff, 11 May 2012 - 10:22 AM.
Posted 11 May 2012 - 10:03 AM
Posted 11 May 2012 - 10:24 AM
Check the Lapdock™ battery level with the battery charge indicator, which is located on the right side of the Lapdock 500.
Charger connected:
Charger disconnected, and phone connected:
Press battery check button:
Posted 11 May 2012 - 11:01 AM
Works now, I talked to a guy from Motorola and it helpedJust in case you haven't found this (not much help I know but Motorola apparently doesn't feel they should have to release a real manual for this):
Charger connected:
- Flashing white - Charging
- Solid white - Fully charged
- Flashing red - Battery below 10%
- Solid red - Battery below 5%
- Solid red - Charge battery
- Double flash white - Low battery
- Triple flash white - Medium charge
- Solid white - Full charge
Posted 11 May 2012 - 01:53 PM
Posted 11 May 2012 - 05:46 PM
Not the same issue but also related to lapdock 500, has anyone noticed that when watching netflix in full screen on the lapdock that if you try to go back using the back button that it will force a reboot of the razr? Just wondering. I am running 181 unrooted and completely stock.
Posted 11 May 2012 - 06:36 PM
Posted 11 May 2012 - 08:10 PM
Posted 12 May 2012 - 06:39 AM
Posted 12 May 2012 - 07:14 AM
Interesting. Sounds annoying but I'll give it a go. Thanks!
