Help redoing my phone
Posted 26 June 2013 - 02:24 PM
Sent from my DROID BIONIC using Tapatalk 4 Beta
Posted 26 June 2013 - 02:28 PM
<p> </p>
<p>Now for some reason before root the driver software for the bionic says it failed to load. I downloaded the new driver link just in case and reinstalled but says the same thing. Any help would be appreciated. thanks</p>
Posted 26 June 2013 - 06:19 PM
Posted 27 June 2013 - 10:28 AM
Wait - what's failing? HoB or rooting?
Posted 27 June 2013 - 05:43 PM
Posted 28 June 2013 - 09:56 AM
What version of Windows? Maybe drivers won't play nice with that version? If it worked and you're back up and running I wouldn't worry about it too much...
Posted 30 June 2013 - 08:32 AM
Posted 30 June 2013 - 12:54 PM
Posted 30 June 2013 - 06:00 PM
I may be wrong be a long time since i redid my moto drivers, but isnt there a 64bit and 32bit version?
Google pixel 32 gig....
Posted 03 July 2013 - 01:07 PM
