I have definitely thought about it. It'll definitely be coming. You ready to test for me?
Sent from my XT926 using Tapatalk 4 Beta
I am always ready and willing.
Posted 28 June 2013 - 08:17 AM
Posted 28 June 2013 - 08:38 AM
Great customer support! Thank you.OK download link should be fixed.
MD5: 1ba41adbe1cebd47bd13783f735cc78a
Proud father of a US Marine
Posted 28 June 2013 - 09:08 AM
I can haz on Bionic?
Posted 28 June 2013 - 01:30 PM
Posted 28 June 2013 - 07:34 PM
Posted 28 June 2013 - 11:38 PM
Posted 29 June 2013 - 01:08 AM
XT926 HD, Working good so far. but All the Icons are so small and the clock/ time. Is there a way to make every thing bigger. Never seen a rom with everything on the screen half the size it used to be. I must be getting old. Do i need to take Viagra?
Posted 29 June 2013 - 01:12 AM
yes you do in settings i think rom control or something you should be able to change DPI
Posted 29 June 2013 - 03:16 AM
Oh yes, Its under Hybrid setting changed Density to 320 and rebooted and now i can see again. Never and to change Density before. Wait, i still cant see.Where is smart actions in this rom. Weird it says its installed but there is no Icon for it either. If i go to the Play store i cant even download it from there. What the?
Posted 29 June 2013 - 03:42 AM
Wifi tether does not work for me either. Built in one or the android wifi 3.3 beta or 3.3 pre 3
