Svoice?
8 replies to this topic
#1 Razroid
Razroid
  • 80 posts
  • LocationSingapore
Posted 15 May 2012 - 05:28 AM
hello, is it possible to port svoice (from galaxy s III) over to our razrs? that should shut those iphone 4s users up.
oh and one more thing, does webtop work if you have a custom rom? i got a hdmi cable and plugged it into my laptop, it did nothing
#2 Nanniepoo
Nanniepoo
  • 298 posts
  • LocationDetroit, MI
Posted 15 May 2012 - 06:46 AM
hello, is it possible to port svoice (from galaxy s III) over to our razrs? that should shut those iphone 4s users up. oh and one more thing, does webtop work if you have a custom rom? i got a hdmi cable and plugged it into my laptop, it did nothing
Depends on the ROM...some get rid of all of Moto's things I think. Unless you do the webtop hack, you'll need some sort of a dock to launch webtop, so just plugging it in won't launch it. You can HDMI mirror without a dock tho...
#3 leviwg
leviwg
    News Writer
  • 563 posts
Posted 15 May 2012 - 07:04 AM
should be able to port it over. might need a mod or two but i think it should just plug right in so pull the files from the phone and look for it in system apps.
a what? an android? whats that?
#4 Razroid
Razroid
  • 80 posts
  • LocationSingapore
Posted 17 May 2012 - 07:40 AM
hmm.. i dont think i can mirror my phone to my hdtv or my laptop, is there any steps on that? and is there a GSIII system rom lying around somewhere? i would love to pull the svoice.apk file out
#5 bstrong
bstrong
    Savior of the Razrs
  • 264 posts
  • Twitter:bstrong11
  • Google+:bstrong9211
  • LocationNorth Carolina
Posted 17 May 2012 - 08:31 AM
I recommend the app "nebtop" from. The market. It's a dock emulator that allows you to bypass the system checks and enable Webtop without the dock
Invictus Maneo!
#6 Razroid
Razroid
  • 80 posts
  • LocationSingapore
Posted 18 May 2012 - 07:11 PM
I recommend the app "nebtop" from. The market. It's a dock emulator that allows you to bypass the system checks and enable Webtop without the dock Sent from my DROID RAZR using Tapatalk 2
yes, i did try nebtop before, did not work on both my hdtv and my laptop
#7 osnoozeo
osnoozeo
  • 108 posts
Posted 21 May 2012 - 01:12 AM
Just so you know, svoice works on the rzr
#8 Razroid
Razroid
  • 80 posts
  • LocationSingapore
Posted 21 May 2012 - 03:21 AM
yea, i have already got that to work, i heard samsung and vlingo is blocking unofficial use of svoice on other devices
#9 TweakedSystems
TweakedSystems
  • 122 posts
Posted 20 August 2012 - 04:34 AM
installed fine ...but I keep getting Network Error.Please try again later :(
Is there a fix for this problem?
