best recovery for restoring backup
5 replies to this topic
#1 shawnlee6184
shawnlee6184
  • 118 posts
Posted 29 June 2013 - 01:57 AM
Wondering what recovery people are using for restoring a backup. I'm having problems with both safe strap and bmm. Thanks. Shawn
#2 jimyv
jimyv
  • 248 posts
Posted 29 June 2013 - 05:10 AM
Are you useing voodoo to fool apps and have a backup of superuser ? If so it will jackup you backups and restore learned this long time ago from person experience lol I stated itvthen and got blowoff lil but ive noticed now it seems to be comon knowledge per devs. Install voodoomand just be sure that you didnt leave a copy by mistake after upgrade and since uninstalled it without deleteing copy...go luck
Sharing da buzz on my crackflashed rzr jimyv
#3 johnthehillbilly
Posted 29 June 2013 - 05:25 AM
What problems are you currently having with safestrap? .....
#4 jimyv
jimyv
  • 248 posts
Posted 29 June 2013 - 07:51 AM
Safestrap rocks!!
#5 livinginkaos
Posted 29 June 2013 - 10:51 AM
Bmm support is slim to none, so I personally would work through whatever issue you are having with safestrap imo
  • johnthehillbilly likes this
#6 jimyv
jimyv
  • 248 posts
Posted 05 July 2013 - 06:45 PM
Resolved?
