ok here is what im dealing with. i bought a droid razer off the internet and they said it was flashed to page plus and now it show up ap fastboot flash mode (S) ( flash failure). i don't know what happened and does anbody know what i can do to fix it. help would be greatly appreciated.
droid razr flash problems
Posted 05 July 2013 - 10:57 AM
Posted 05 July 2013 - 11:00 AM
Use Matt's utility -
option 1, should fix you up.
Posted 05 July 2013 - 11:18 AM
thanks ill try it and let you know if it worked
Posted 05 July 2013 - 11:38 AM
ive run into a problem the phone is about dead and i cant get it to charge now what do i do
Posted 05 July 2013 - 11:47 AM
sent via RazrMaxx over Tapatalk, y'all!
Plug the charging cable into the phone - Hold the PWR and the Volume UP & DOWN all at the same time for 10 seconds , then hold just the Volume UP & DOWN for 10 seconds to put you in the boot menu. Once there, scroll down to BP Tools and select it by pushing the PWR button. It might look like it is booting, but it should end up with the charging screen.
Posted 05 July 2013 - 12:20 PM
i got it to charge and did the utility but now on the ap fastboot screen it say script fail
Posted 05 July 2013 - 12:22 PM
Is this the XT912?
Posted 05 July 2013 - 12:26 PM
yes
Posted 05 July 2013 - 12:28 PM
it says error cannot load system.img and error cannot load recovory.img
Posted 05 July 2013 - 12:29 PM
Be sure to get the phone charged completely and try it again - option 1 .
Posted 05 July 2013 - 12:31 PM
ok i will let you know what happens
Posted 05 July 2013 - 01:39 PM
it still didnt go through with having a full battery is there any other sugestions?
Posted 05 July 2013 - 01:55 PM
Posted 05 July 2013 - 01:56 PM
no can you explain how
Posted 05 July 2013 - 02:46 PM
Posted 05 July 2013 - 04:27 PM
It would take an hour to explain how to manually flash partition files with fastboot if you don't know anything about it. Where did you buy this phone
