[Mod] Disable internalSD & use externalSD for everything... WIP
7 replies to this topic
#1 aviwdoowks
aviwdoowks
  • 140 posts
Posted 07 July 2013 - 09:34 AM
Once I get more testing done I may write a script. Yet it is very easy to just paste to an initd enabled stock base rom. Set permissions and owner the same as it's relations there. Back up before you try it.
FOR UNLOCKED BOOTLOADERS ONLY.
Source :
 ZaYAC-ua and his Backup Rom: Avstralia Deodex Mod by ZaYAC for XT907 at XDA
I got the swap working for these stock base roms w/ initd : DeadRage and Flying Jelly  Though it is not really a swap, the emulated portion of internal memory is rendered useless and you delete everything there. Your SDcard is now seen as storage0. Storage1 points to Internal memory.
The Settings/Storage will judge things incorrectly now.
Just be sure all media is backed up before you reboot.
Now you have all internal memory for apps.
Upload in not flash-able.
Someone Please step in and get this working for CM based roms?
Code from the upload:
#!/system/bin/sh
#extsd2internalsd is a modification that allows to switch internal sd to external sd and viceversa. With this you can use default internal sd only for app storage #and the external sd to store all apps resource and all others stuff. The resut is a very big increase of installable apps on gs3
#All credits to Mattiadj of xda forum for the idea and script and to mike1986 for the cmw zip.
#xda thread url at
#Script Modified for U.S. Galaxy S3s by Zedomax at GalaxyS3Root.com to be compatible when sdcard is not inserted.
busybox mount -o remount,rw /
busybox mount -t vfat -o umask=0000 /dev/block/vold/179:97 /mnt/sdcard
busybox mount -t exfat -o umask=0000 /dev/block/vold/179:97 /mnt/sdcard
if busybox mount | busybox grep vold/179:97; then
busybox mount -o bind /data/media /mnt/external1
fi
End code
#2 villinovanxtgen
villinovanxtgen
  • 22 posts
Posted 07 July 2013 - 09:42 AM
Do you think this would solve Encryption unsucessful errors on some droid razrs Xt912
#3 aviwdoowks
aviwdoowks
  • 140 posts
Posted 07 July 2013 - 09:46 AM
No idea.  Executive Noob here.
#4 villinovanxtgen
villinovanxtgen
  • 22 posts
Posted 07 July 2013 - 09:56 AM
haha me aswell but you should look into that i think you just created a soultion!
#5 aviwdoowks
aviwdoowks
  • 140 posts
Posted 08 July 2013 - 07:43 AM
What is the encryption problem? Does it exist on the M?
#6 villinovanxtgen
villinovanxtgen
  • 22 posts
Posted 08 July 2013 - 08:59 AM
No i don't believe so ive only encountered it in the OGrazr
#7 Someolddude
Someolddude
  • 426 posts
Posted 09 July 2013 - 07:26 PM
Noob here also but I see a problem. Storage sdcard0 on my phone is internal. I have to use storage sdcard1 to get things on my external SD. I know when the SD card is mounted its seen as system storage because of how GL to SD app works.
#8 aviwdoowks
aviwdoowks
  • 140 posts
Posted 11 July 2013 - 06:41 AM
GL.. or anything other than FolderMount, will not work on the 'M.
I hate how the internal will get wiped during a RSD restore ( maybe at other times too). This is a great work around only for Initd enabled (will not work on the rooted stock rom) stock base roms. I hope to get it to work for Miui
