Volume adjusting stays on screen
willmiii
, Jul 08 2013 09:16 AM
3 replies to this topic
Posted 08 July 2013 - 09:16 AM
I was wondering if anyone can help me. As the title indicates, whenever I adjust the volume on my stock rooted M it stays on the screen. I know its supposed to fade away shortly after adjustment but mine doesn't. I can turn the display off by pressing power button and when I turn it back on its still there.
Posted 08 July 2013 - 01:13 PM
Dumb question maybe, but did you try a reboot?
The price of liberty, and even of common humanity, is eternal vigilance. -- Aldous Huxley
Always do what is right. It will gratify half of mankind and astound the other. ---Mark Twain
Posted 10 July 2013 - 01:20 PM
Tried a reboot. It only goes away after touching the screen. Otherwise it will remain on screen until i took the phone to manually remove it.
Posted 14 July 2013 - 03:42 PM
I'm thinking an app you downloaded is causing the issue.
