JB kexec ROMS with ICS moto base
3 replies to this topic
#1 chrisp6825
chrisp6825
    Byaaah!
  • 78 posts
  • Current Device(s):Moto Droid Bionic
Posted 09 July 2013 - 07:00 PM
Heya. I wanted to grab some input if anyone is running any setups like this.
I faintly remember running ICS kexec ROMS while having the GB moto bases installed, and there were problems regarding data connectivity, camera, and other, minor issues.
Has anyone experienced issues at all running a JB kexec ROM while having a ICS moto base still installed?
#2 LDubs
LDubs
    Pawn In Game of Life
  • 9,130 posts
  • Twitter:lew_bklyn
  • LocationBrooklyn, NY
Posted 10 July 2013 - 11:43 AM
It works just fine - I ran kexec-based CM10.1, AOKP and LiquidSmooth JB 4.2.2 ROMs while on ICS base.  Then I upgraded to JB and continued to run them... data works, bluetooth works, camera works.  Some have reported issues with GPS lock (fixed by booting into stock, firing up GPS and then going back to other ROM) and MMS not sending through stock messaging (I think fixed by sending from Go or Handcent and then going back to stock messaging).
edit - just saw from your profile you're on .232 - note that if you want to upgrade to JB (you should, has some new features) it won't work OTA.
#3 chrisp6825
chrisp6825
    Byaaah!
  • 78 posts
Posted 10 July 2013 - 05:31 PM
Cool, good to hear, I've actually started playing with Carbon ROM (hence why I made this post, but figured I'd try it first hand as well).
But yea, I haven't found any bugginess so far, although I haven't tried GPS or MMS yet, will have to do that..
And yes, I am aware I'm off OTA path. 232 was the last (or close to last) leak that could go back to GB moto base, so I stayed here.
Flashing back to GB has helped in getting my old MAC address back after flashing ICS ROMs. If JB kexec on ICS base works out well enough, I'd still consider no reason for me to move ;P
BTW, you mention new features on the JB upgrade.. the new features are only apparent inside the stock ROM, correct? I wouldn't think I'd be missing out on any features if I'm not running stock ROM, but I've been wrong before :)
#4 nitephlight
nitephlight
  • 82 posts
Posted 10 July 2013 - 08:06 PM
we didn't get anything worth while with the JB update- no built in toggles OR moto quick settings. on stock JB kernel feels a bit more slick but hard to say. chrome still permastuns me, so hopes have died. id go back to GB if i could and fire up webuntu. this phone is EOL unfortunately
