I have had no luck finding a thread which will help me...with links for the downloads that actually still work..I am rooted and safestrap is installed..
I'm trying to factory reset my phone to right out of the box status..
I've tried getting into recovery mode and flashing the file off of the SD card, which I've done before, but not I get the robot with the red exclamation point.. I've read threads which state you can push both volume buttons to remedy this, which still doesn't work.
I've never used ABD and am not sure what that is. I've tried to use the RSD and matt's utility and matts utility Opt 1 wouldn't work. My phone was in ap fastboot, drivers installed and debugging was enabled..I pressed enter and it didn't recognize the phone..
I'm lost and need some guidance please.
