Yup I'm boned. Any one got any amazing ideas? Its still booted when it was charged. Any way to force charge the battery.
OK so I'm going for the sliver lining here I've still got a screen that should be good so I can get a damaged phone cheap and try again. Can some help me with modding the systemui and and setting images correctly. And please be detailed I'm not completely stupid but Im kinda new to this and I did break this phone.
You can force a charge (providing the battery is not hosed) by opening the phone and locating the screw in battery terminals.... cut the end off a USB cord and strip insulation off of the 5v and ground (typically red and black respectively) strip only about ΒΌ inch .... loosen the terminal screws and place the wires under the screws then retighten...... use great care on the polarity ... and great care that the wires do not touch anything else....... this is a very successful way to charge but is extremely risky if you are not 100% sure what you are doing......
On modding the systemUI.apk..... if all you are doing is replacing .pngs then you can use 7zip to open(not extract) the systemUI.apk.... make sure the .pngs you are using are named and sized properly (they need to match the ones you are replacing) ..... drag and drop into the appropriate folder..... stay away from the .9pngs as you cannot replace them this way and systemUI will fail and crash(FC)
This way there is no need to decompile,edit,and recompile the .apk with apktool(or similar )
Note.... this is usually successful but there are times when systemUI.apk is just stubborn and refuses anything you do to it.....
... telekinectically tapping, tenaciously traversing the terrain...
