First off, a huge thanks to all the devs that work on this. Its fantastic.
positives so far -
Buttery Smooth.
Very Stable
48 hours talk time w/ ease. I am getting better battery life. using CPU identifier I can see that one of the cores is typically parked. this was never the case on stock.
WiFi and Data signal strengths are very close to stock (had to manually change from International to CDMA/LTE mode)
Google Edition Boot Animation is ultra fast - beats old boot time by a few seconds, plus its cooler
GPS is not a problem at all. Works very well.
Plus all the other CM perks....
Negatives so far -
Reflashing boot animation after nightly update is annoying. So I only plan on updates once weekly.
Bluetooth is totally non functional. Sends my device into bootloop when I connect via bluetooth and launch google music. Holding power down and Power will get me up and running.
Had a few issues with privacy Guard at first - but resolved them by heading into Apps and disabling Privacy Guard on a few apps.
This could by purely coincidental, but both of my Moto rapid chargers don't work immediately after flashing CM. My wifes S4 charger works fine, so does my official moto charger that came with the HD.
When updating a nightly, the first time i try itll always boot up to the recovery without updating. Rebooting into system and trying again always works.
