Posted 23 May 2012 - 10:23 PM
This is the first time I have posted on any fourm, so If I am in the wrong place or am doing something wrong, Sorry.
Posted 23 May 2012 - 10:53 PM
Have you given this a shot?
- Atomic39 likes this
Posted 23 May 2012 - 11:15 PM
Posted 23 May 2012 - 11:23 PM
No Luck with that either. What is the special cable called, I read somewhere that you can get it on ebay.
Posted 24 May 2012 - 12:05 AM
If you are comfortable with soldering you can make your own factory cable using this
Posted 24 May 2012 - 07:02 AM
Posted 24 May 2012 - 07:11 AM
Thanks, do I need to leave the phone plugged in until then or is it ok if it goes off.Check TBH if you can order you will get it pretty quick. Bout 20 or 30 i think. Well worth the money.
Posted 24 May 2012 - 07:24 AM
Posted 24 May 2012 - 07:26 AM
well then you kick yourself in the butt when you find out what I know! go to bp tools, plug the phone using a wall charger and reboot with bp tools settings. it will charge your phone without a special cable!
Posted 24 May 2012 - 07:47 AM
I can also confirm that this works. Figured it out a few days back while fooling around with my bricked MAXX.well then you kick yourself in the butt when you find out what I know! go to bp tools, plug the phone using a wall charger and reboot with bp tools settings. it will charge your phone without a special cable!
Posted 24 May 2012 - 09:00 AM
will the screen have something different on it or the same "device locked, status code:0 "I can also confirm that this works. Figured it out a few days back while fooling around with my bricked MAXX.
ect.
Posted 24 May 2012 - 09:12 AM
What you want to do is, with your phone on or off (doesn't) matter, hold down volume+ volume- and power all at once. When the screen flashes, release power briefly then press and hold again. This will get you into boot menu tools. Scroll all the way down to the bottom with the volume down key and select the last option called bp tools with the volume up key. Make sure the phone is plugged into an outlet when doing this. I apologize, I didn't mean ap Fastboot mode.will the screen have something different on it or the same "device locked, status code:0 "
ect.
Posted 24 May 2012 - 10:33 AM
I have tried that a hundred times, I cant get it to do anything but jump back to the screen that says Ap Fastboot mode (s) (boot Failure)0A.66What you want to do is, with your phone on or off (doesn't) matter, hold down volume+ volume- and power all at once. When the screen flashes, release power briefly then press and hold again. This will get you into boot menu tools. Scroll all the way down to the bottom with the volume down key and select the last option called bp tools with the volume up key. Make sure the phone is plugged into an outlet when doing this. I apologize, I didn't mean ap Fastboot mode.
Posted 24 May 2012 - 10:45 AM
Posted 24 May 2012 - 10:52 AM
I made a thread to fix that a while back... let me see if I can find it. Basically you just need to have a successful flash of ANYTHING to clear it. It's registering the fail til then.
Posted 24 May 2012 - 10:53 AM
Posted 24 May 2012 - 11:18 AM
It was working and I made it here"moto-fastboot flash mbmloader mbmloader_hs.bin" and the battery went down again.If only I could type faster. . Do it sooner than later because the phone won't charge while you've got it stuck in that mode.
Posted 24 May 2012 - 11:23 AM
Posted 24 May 2012 - 05:33 PM
I just got home and tried it again on the bricked razr, I had it wrong. With the phone plugged in the outlet, boot into boot mode selection menu from ap fastboot mode, and select bp sbf flash. It lets your phone charge even, when bricked, at least it does mine. When your on the Ap fastboot screen, hold vol up and down at the same time and tap the power button twice. It will bring you to the boot mode menu.I have tried that a hundred times, I cant get it to do anything but jump back to the screen that says Ap Fastboot mode (s) (boot Failure)0A.66
Posted 25 May 2012 - 06:22 AM
That's not working either. I guess the only option I have is to try and make the factory cable. If anyone has any advice I would be very thankful. Like I stated in my first post this is the first time posting anything on a forum. That's not to say that I am a complete beginner with Android, I have been Rooting phones and flashing custom roms for about two years. But the Forum I started with would give Beginners a hard time, it seemed. I guess this was the cause for my worry about posting or asking a question. But I would like to thank all of you that helped me on this problem, You kindness and help Is very appreciated. I have now found a new home for all my Razr needs, that's until you evict meI just got home and tried it again on the bricked razr, I had it wrong. With the phone plugged in the outlet, boot into boot mode selection menu from ap fastboot mode, and select bp sbf flash. It lets your phone charge even, when bricked, at least it does mine. When your on the Ap fastboot screen, hold vol up and down at the same time and tap the power button twice. It will bring you to the boot mode menu.
