Several things to look for:
- Its possible you have an App or Apps thats drawing on your battery
- Example, GPS,Streaming, Music, Video, Tethering or Running Apps in the background
- Possibly a Bad USB Port for Charging
- You mentioned you changed your Battery or You mean you charged you Battery
- My guess, this is going to be a search and find mission for you...
Or you have a Defaulty Phone that needs to be returned...
No, it's not an application because fails outside of android. For instance, it's charging in charge mode and it shows 100% but then when it boots maybe you get 48% of charge then you plug it again and in a matter of seconds you have that precious full charge. Sometimes it works for a while well and other times drops from 100% to 48%, 20%, and so on.
That's why I though it needed a battery replacement so I did it but the issue keeps.
Thanks "The persuader", It's a difficult mission and nowadays is a "Mission: impossible" lol
I'm trying not to return it because I've got to spend a lot of money because it's a international shipping that's why I want to rule out all possibilities.
You can also use the Utility
to return to out of the box stock
I did't it several times. I tried a lot of custom roms, stock rom even ubuntu version . Something weird...not always but sometimes it turn off itself (but in the bad way).
Just to know, what is the average of use in your devices? (something standard....whatsapp, sms, browser) No games, no music.
I know, this issue is a challenge!!
Thanks guys.
