Setting Ad-Hoc Mode Failed. Wifi Tether. Help?
Posted 30 May 2012 - 09:55 AM
Posted 30 May 2012 - 10:30 AM
Posted 30 May 2012 - 12:22 PM
Didn't have issues on GB.
Posted 30 May 2012 - 09:08 PM
Posted 24 June 2012 - 07:21 PM
Posted 24 June 2012 - 07:41 PM
setting my droid razr maxx to "generic ics" worked. thanks. Also got the sql lite editor method to work as well.
Where do I find this setting? Where is device profile please?
Posted 30 June 2012 - 09:00 PM
#8 Guest_BDH_*
Posted 01 July 2012 - 12:15 AM
Open the Wifi Tether app and press the menu button on your phone, then select "Settings."
Look for "Change Device Profile"
Edited by spc_hicks09, 01 July 2012 - 12:15 AM.
Posted 01 July 2012 - 11:20 AM
Posted 01 July 2012 - 02:18 PM
Be patient after it fires up, it takes about 2 mins then that unidentified limited connection gets solid.
- Pego99 likes this
Posted 01 July 2012 - 07:27 PM
Posted 01 July 2012 - 08:27 PM
#13 Guest_BDH_*
Posted 01 July 2012 - 08:33 PM
I wish Wifi Tether worked. Its much more stable and faster than Foxfi or the built in hotspot
I got Wifi Tether to work with my instructions in Post 3 for KOA ROM, don't understand why it's not working for other people.
Posted 01 July 2012 - 09:11 PM
I've tried your instructions several times with no luck. I've played with all the settings in Wifi Tether... nothing.I got Wifi Tether to work with my instructions in Post 3 for KOA ROM, don't understand why it's not working for other people.
Posted 01 July 2012 - 09:24 PM
I have just tried your settings from your post. They allow my laptop to connect to my phone, but it has no internet access. This is just my guess, but it might be that since your on the KOA ROM, there are areas of the system that are open when compared to a "stock" rom. I'm on the stock, rooted .211 leak by the way. Wifi Tether has never worked for me on any of the ICS leaks. The only thing that has work so far, for me, is FoxFi. This is just my opinion and more than likey I'm totally wrong.
