Xt926 stuck in Decrypted unsuccesfuly
3 replies to this topic
#1 Snaper
Snaper
Posted 27 July 2013 - 02:48 PM
Hello everyone in the forum, I did a hard reset on my XT926 but when it reboot stayed on the screen "Decrypted unsuccesfuly"
I tried to flash with rsd lite, but when the phone switches to fastboot, rsd lite displays an error, and I can not run my phone.
Tanks for your help
#2 Snaper
Snaper
Posted 30 July 2013 - 01:12 PM
Anyone can help me?
#3 johnthehillbilly
Posted 30 July 2013 - 03:43 PM
That's an error I personally have not seen..... will try to look for a suitable answer for you :)
... telekinetically tapped, tenaciously traversing the terrain ...
#4 crepiduse
crepiduse
  • 21 posts
Posted 08 August 2013 - 08:54 AM
Was your filesystem encrypted?  If so,  you needed to decrypt via correct pass/pin/lock.
If not,  there may be a easy fix for you.   Is your phone unlocked or was it rooted?
