best way to restore phone
3 replies to this topic
#1 bingo6104
bingo6104
  • 60 posts
Posted 30 July 2013 - 03:26 PM
Well i am having a lot of issues withmy gps not working. All has been fine when i was running Jellywiz  rom and decided to try some new roms. Mostly CM based like avaitor,butter etc. Well I am not sure if something happen during flashing roms but even my gps doesnt work on my stovk rom slot. I always deleted the slots in SS and recreated them and installed the roms. Doesnt make since that the stock rom isnt working?
So what would be the best way to wipe everything and start over? I am hoping that will fix the problem. Unless any body has some other suggestions? If i wipe the internal memory, all my apps should be ok as long as I am back them up with TiBu correct?
#2 livinginkaos
Posted 30 July 2013 - 03:35 PM
If you want a fresh start use Matt's utility option 1.
  • rickw, bingo6104 and johnthehillbilly like this
#3 bingo6104
bingo6104
  • 60 posts
Posted 30 July 2013 - 04:10 PM
That's what I was thinking . It will be as it came out of the box,right?
Sent from my Motorola Galaxy s3 using Tapatalk 2
#4 johnthehillbilly
Posted 30 July 2013 - 04:15 PM
Indeed it will :)
... telekinetically tapped, tenaciously traversing the terrain ...
  • bingo6104 and livinginkaos like this
