Upgrade From Ics Leak To Ics Leak?
Posted 03 June 2012 - 02:26 PM
I got my Razr a couple days ago, and flashed the .79 leak (since it was considered safe). Well my curiosity got the best of me and I fastbooted back to .181, then flashed the latest .209 leak today (by tossing the zip and crc in /cache then using rom manager to install).
To my knowledge, all the leaks that are being released are only flashable over .181, hence the name of the zip. If/when another leak comes out, is there a procedure for upgrading from one ICS leak to another?
Thank you!
Posted 03 June 2012 - 02:46 PM
- shobon likes this
Posted 03 June 2012 - 06:36 PM
are you downloading the leaks right to phone or computer and then transferring? I'm trying to find someone that made it by just simply dl to phone without computer..it should work...I have 30mbs speeds...Excuse me if this has been asked about before, but I couldn't find anything about it.
Thank you!
Simply Amazing ...
Essentially Stunning,
Motorola Droid Razr---->Minimum<-----
Tapped via Red Xparent Pro>:-!
Posted 03 June 2012 - 07:06 PM
Simply Amazing ...
I've been downloading them to my computer then tossing them on my phone. I have a 4gb data cap that I don't want to waste downloading leaks
Posted 03 June 2012 - 08:24 PM
no problem bro.. I use wifi even though I'm 4g unlimited. I also have throttle modded but never use it on this device since its fast enough and unlimited.. anyway thanks bro.. much appreciated for your response. I was just curious as I never hear of anyone doing it this way anymore. I always do but I know this leak or these are huge due to web top..lolI've been downloading them to my computer then tossing them on my phone. I have a 4gb data cap that I don't want to waste downloading leaks
Simply Amazing ...
Posted 03 June 2012 - 09:16 PM
Simply Amazing ...
Motorola Droid Razr---->Minimum:-!
I dl everything over 4G. My wifi (VZ DSL) is slower than 3G so I find I have no other choice.
Sent from my Soldiered up Razr Maxx
Posted 03 June 2012 - 09:24 PM
Same here.
Posted 04 June 2012 - 12:35 PM
Simply Amazing ...
