Not Booting After Custom Rom Flash
Posted 03 August 2013 - 02:33 PM
Posted 03 August 2013 - 02:37 PM
which cyanogen mod did you flash? cyanogen mod has a custom kernel which you cant flash while on safestrap and having a locked bootloader
edit: please look at these
Need an unlocked bootloader and be using a custom recovery to use cyanogen mod or anything based off it
One -
Two -
- thejoshman likes this
Posted 03 August 2013 - 03:24 PM
One -
Two -
I just flashed the nightly build that just came out today, any recommendations of custom roms that don't run off Cyanogen? As I heard unlocking your bootloader erases your phone (apps contacts etc) Could I also keep using Safestrap if I do decide to unlock my bootloader and use Cyanogen?
Posted 03 August 2013 - 03:58 PM
Unlocking your boot loader does not erase anything. Once its unlocked you no longer need safe strap.
sig made by
Rinkle McBally
Posted 03 August 2013 - 04:02 PM
Should I start using Rom manager then? I started using safestrap becayse of how safe it is.
Posted 03 August 2013 - 04:19 PM
As long as you read directions and don't try flashing crazy stuff an unlocked boot loader is safer than safe strap. And you don't need ROM manager . read about twrp or cwm flash which ever you choose and make sure to follow directions!
sig made by
Rinkle McBally
Posted 03 August 2013 - 04:31 PM
Ah, so I could just uninstall SafeStrap unlock the bootloader put this on it
and flash cyanogen? Also what would happen if I lets say flash LiquidSmooth for 4.2.2 while running 4.1.2.#8
Posted 03 August 2013 - 04:40 PM
You need to flash twrp that's built for your device. Its in the development section than going from 4.1.2 ROMs to 4.2 or 4.3 ROMs is no problem just follow directions.
sig made by
Rinkle McBally
Posted 03 August 2013 - 04:51 PM
All this does seem pretty complicated, especially flashing TWRP. Hopefully Ill get it right and dont brick my device.
Posted 03 August 2013 - 04:54 PM
As long as you read the directions a few times and follow them you'll be alright. If your unsure about something feel free to ask for help that's why we are here.
sig made by
Rinkle McBally
Posted 03 August 2013 - 04:58 PM
Alright thanks a lot. From my understanding all I need to do is unlock the bootloader flash TWRP and Ill be able to boot into recovery and from there flash custom roms.
Posted 03 August 2013 - 05:03 PM
Correct make sure to make a backup before flashing anything and put it on your SD card and possibly you PC to be safe
sig made by
Rinkle McBally
Posted 03 August 2013 - 05:05 PM
I don't have a SD card. Ill just put it on my PC. Thanks a lot for the help, I can finally fully customize and enjoy android. Could you link me to one of the threads that explains getting from 4.1.2 to 4.2/4.3?
Posted 03 August 2013 - 05:13 PM
Just flash the ROM and follow whichever ROM you choose directions. And you might wanna get a sdcard to be safe
sig made by
Rinkle McBally
Posted 03 August 2013 - 05:19 PM
Ok will do, LiquidSmooth didn't have any directions really. Thanks a lot for the help again.
Posted 03 August 2013 - 10:23 PM
