Problem Fastbooting with Matt's latest utility
11 replies to this topic
#1 WhySoSamek
WhySoSamek
  • 11 posts
  • Twitter:WhySoSamek
Posted 05 August 2013 - 07:52 AM
I've screwed myself royally and am looking for help.
Current situation:
. Rooted. Currently on the christmas jb leak and am wanting to update. BUT i accidentally wiped my stock side of ss3, before i uninstalled the recovery. It wont boot anywhere past the M logo. I am able to get into recovery and fastboot. I downloaded the latest JB utility from Mattlgrof and am able to run the script but after putting my phone into fastboot, and selecting the first option, the script appears to run but my phone stays on the fastboot screen. I have wiped and cleared the cache and FDR multiple times, I have full battery going into each attempt. I am using the
cable that came with the phone. the utility script runs the same whether or not i have the phone plugged in. Im working from a macbook, any suggestions? thanks in advance
This is what the script reads while my phone is unresponsive
"dyld: unknown required load command 0x80000022
./linuxmacutility.sh: line 108:  5500 Trace/BPT trap          sudo $fastboot flash mbm allow-mbmloader-flashing-mbm.bin
#2 cmh714
Posted 05 August 2013 - 07:57 AM
Thanks for posting here instead of email....the others can assist here as well.
So I assume your using Matts latest here:
From searching it seems you may have the wrong or an outdated version of adb.....
#3 WhySoSamek
WhySoSamek
  • 11 posts
Posted 05 August 2013 - 01:21 PM
The only adb I have is what it included with the utility... Where would I find an updated or correct version? Maybe I am needing additional adb outside of the utility? Thanks
#4 timpohladthomas
timpohladthomas
    OSE DEVELOPER
  • 1,428 posts
  • Twitter:@timpohladthomas
  • Current Device(s):MOTO X
Posted 05 August 2013 - 01:31 PM
What Operating System are you on? Did you unzip the utility folder?
#5 WhySoSamek
WhySoSamek
  • 11 posts
Posted 05 August 2013 - 01:54 PM
Yes I unzipped the folder and I am on Mac OSX 10.5.8
#6 cmh714
Posted 05 August 2013 - 04:58 PM
so then in a Terminal windo change into that folder, then chmod the LinuxMacUtiliy.sh file so its executable, then run it, and hopefully that should work.
#7 cmh714
Posted 05 August 2013 - 05:00 PM
since thats a dated version of OSX I am not sure if thats the correct adb version for you though....since matts utiliy is newer.....
#8 WhySoSamek
WhySoSamek
  • 11 posts
Posted 05 August 2013 - 06:21 PM
Okay. I have no trouble opening and running the file. The phone is just unresponsive once attempting the fastboot. I may be able to try it on a newer OS. Thanks again!
#9 johnthehillbilly
Posted 05 August 2013 - 06:26 PM
Does it show any errors in terminal while running...... and are you on one the rare 32 bit breeds of OSX?...... we have seen several problems with those and the utilities .....
... telekinetically tapped, tenaciously traversing the terrain ...
#10 WhySoSamek
WhySoSamek
  • 11 posts
Posted 05 August 2013 - 07:38 PM
I dont see errors coming during the terminal except for
It looks like I may be on a 32 bit system. Is there anyway I can get around that?
Correction: I am on a Intel Core 2 Duo 64 bit, but for some reason within the utility it says 32 bit system?
Edited by WhySoSamek, 05 August 2013 - 07:47 PM.
#11 cmh714
Posted 06 August 2013 - 05:10 AM
you can try and edit the script file. Change the references for fastboot.osx32 to fastboot.osx and see if that works. First make a copy of the script.....
#12 johnthehillbilly
Posted 06 August 2013 - 05:18 AM
Your processor may show 64bit compatible but your OS may be a 32bit.... the easiest way to tell for sure is open terminal and type uname -a ... it should give you all the necessary information :)
And we can go from there :)
