I'm having a problem rooting using your motochopper file. Every time I run the run batch file, this is the output that I get... I have the USB Debug on, running RSD Lite v5.6... Can anyone give me any advice? What am I missing?
[*] Motochopper: Android root exploit (Windows version)
[*] v1.0
[*] Tested on the Motorola Razr HD, Razr M, Razr Maxx HD, and Atrix HD.
[*] Supports lots of other devices as well. ;-)
[*] Before continuing, ensure that USB debugging is enabled, that you
[*] have the latest USB drivers installed, and that your phone
[*] is connected via USB.
[*] WARNING: This will likely void the warranty on your device. I am
[*] not responsible for any damage to your phone as a result using this
[*] tool.
[*] Waiting for device...
[*] Device found.
[*] Pushing exploit...
3628 KB/s (1283460 bytes in 0.345s)
[*] Pushing root tools...
3441 KB/s (366952 bytes in 0.104s)
3275 KB/s (1867568 bytes in 0.556s)
3491 KB/s (1578585 bytes in 0.441s)
pkg: /data/local/tmp/Superuser.apk
Success
[*] Rooting phone...
[+] This may take a few minutes.
[-] Failure.
[*] Cleaning up...
[*] Exploit complete. Press enter to reboot and exit.
Thanks for your help.
