I finially have ics on my phone, and was wondering where the governor settings was located. Brain is fried atm..;/
Not Sure If This Is In The Right Spot.
blaten22
, Jun 06 2012 03:55 AM
4 replies to this topic
Posted 06 June 2012 - 03:55 AM
Posted 06 June 2012 - 04:07 AM
Are you running a custom ROM or the leak?
Posted 06 June 2012 - 07:03 AM
Atm, just the 209 leak. I'm undecided if I'm going to flash a rom yet. Figured with the leaks coming, that in it self would be enough flashing.
Posted 09 June 2012 - 09:00 PM
There are no settings for the governor in stock ROM. You will either need to be using an app like setCPU or a custom ROM with the controls baked in already.
#5 Guest_BDH_*
Posted 09 June 2012 - 10:07 PM
The development section is only meant for posts that are development related, not questions. This thread is being moved to the "Help" section.
