Hi all, having a bit of a problem here, (that was sort of obvious, wasn't it?)
Anyways, I am trying (very hard indeed) to get Matt's Utility to root my RAZR, (XT912, that is, with 98.72.16).
If you look at the return from terminal, I think it's pretty obvious where the problem is, but I absolutely for the life of me cannot figure out how to fix it. I even tried adding sudo to every command (excluding read, because the command fails if you do), but that too did not fix the problem/successfully root my device.
Terminal Return (Made into pretty bad format because of the forum,so I would recommend a download, but your call...)
Spoiler
[1] Flash Official Jellybean Firmware (Wipe Data) [2] Flash Official Jellybean Firmware (No Data Wipe) [3] RAZR Blade 4.1.2 Root by Djrbliss [4] Install Safestrap 3 App by Hashcode press any key to exit Make your choice 3 32 bit Linux System * daemon not running. starting it now on port 5037 * * daemon started successfully *
Before continuing, ensure USB debugging is enabled, that you
have the latest Motorola drivers installed, and that your phone
is connected via USB.
Please carefully follow any instructions provided in the exploit.
Press enter to root your phone...
Waiting for device...
Device found.
Phase one...
Rebooting device...
Waiting for phone to reboot.
Phase two...
Complete the following steps on your device:
1. Open the Smart Actions application.
2. Select Get Started.
3. Select Battery Saver.
4. Select Save.
5. Press the Home button.
Press enter here once you have completed the above steps. 84 KB/s (3477 bytes in 0.040s)
Rebooting device...
Phase three (this will take a minute)... failed on '/data/logger' - Permission denied mkdir failed for /data/logger, File exists Unable to chmod /data/logger: Operation not permitted link failed File exists
Rebooting device...
Phase four... 4189 KB/s (543080 bytes in 0.126s) 3971 KB/s (1867568 bytes in 0.459s) 5066 KB/s (476557 bytes in 0.091s) 1541 KB/s (63838 bytes in 0.040s)
Cleaning up... /system/bin/sh: su: not found
Rebooting...
Exploit complete!
Press any key to exit.
...sorry for the bad formatting...that's the forum for ya...
Anyways, I just realized the the Low Battery Smart Action never turned on after creating this. Whether it's not supposed to if it should've, probably something worth noting. I'm going to actually mannuall turn it on and see what happens.
Any help would be greatly appreciated, and thanks in advance, staMerrill
Thanks, but I would like to try and avoid factory resetting if possible, but I'll go ahead and clear SA's cache and data. I was going to try that earlier, but the apps page was taking forever to load, and I got impatient...
Current Device(s):unlocked RAZR HD (xt926)... RAZR (xt912)
Posted 08 August 2013 - 06:35 PM
You should be able to install or reinstall the backup assistant app and restore your contacts etc..... then uninstall if you choose..... are your contacts not backed up to Google as well?
"... try not... do or do not! .... there is no try ... "
I have my Google contacts in addition to the contacts that are stored with Verizon. Unforunately, from the days of Dumb Phones, a large number of my contacts aren't stored with Google, even though all new ones I create are.
Anyways, will try with the installing BUA and getting the contacts like that.
Posted 08 August 2013 - 08:09 PM
Once you have all you contacts, you can create a .vcf of all your contacts on your SDcard so you will have a "local" backup of them as well..... then you can add them all to your Google account as well
Memnoch73 likes this
Alright, so thanks for all the help, everyone. Successfully installed CM10.1.2 Spyder, which is working fantastically. Naturally, as is for Google, they completely restored everything back to what it was when I left stock, which is awesome...
So yes, thanks for all the help. And as one last thing, I noticed when I installed Verizon Cloud, (as it is called now, it's not Backup Assistant+ anymore), to get my contacts back, it easily slowed down CM by at least a factor of 2, and this is a single app! (I do, on the other hand, have 193 other apps). Anyways, good news is, is that after I uninstalled it, everything was back up to speed...I guess just an emphacis on how much bloatware can slow you down.
