Vanilla RootBox Razr M 8/08/13
31 replies to this topic
#1 somber73
somber73
    Ringmaster
  • 466 posts
  • Twitter:@xSomber73
  • LocationNY
  • Current Device(s):Razr M
Posted 08 August 2013 - 05:28 PM
Description
Vanilla RootBox is built straight from
and always carries a very light installation with no extra/useless apps. This means, you can enjoy a pure Android experience combined with AOKP/CM/PA features. Every RootBox releases are stable and always up to the challenge for a daily usage. If you're wondering how this ROM differs from any other AOKP roms out there, I only have one thing to say: Try it yourself and choose the one that meets your requirements.
Features
Built from
For a complete list of all Features in RootBox, visit the following link:
AOKP Features
Hybrid Settings
Per App DPI
Per App Colors (Statusbar, Icons, NavBar)
Per App UI (Phone, Tablet, Phablet)
Per App Expanded Mode (FullScreen)
NavBar Height
General Settings
Home button call answer (Accessibility Option)
Variable Lockscreen Pattern size (CM)
Quiet Hours (CM)
Power Sounds (CM)
Camera Shutter sound
Permissions (AOKP)
Profiles (CM)
Update Center – OTA Updates through GOO Manager
Camera
Save pictures to external memory
Timer Shutter
Voice Shutter
Power Shutter
Picture Size
Focus Mode
Color Effects
Exposure
White Balance
ISO Settings
Scenery Settings
Smart Shutter
Store Location (GPS)
Burst Shots
Clock
Clock: Increasing Alarm
Clock: Flip/Shake – Snooze or Dismiss
Clock: Disable Alarm Icon on Statusbar
MMS
Easy selector
Privacy Mode
Quick Message
Wake and Unlock
Strip Unicode
Emoji support
Direct Call
Message font size
Text area size
Phone
Blacklist
Noise supressiony, Off)
Flip Actions
Phone: Advance Phone Settings (Vibrate on Answer, Every 45 Seconds, On Hangup and On Call Waiting)
Rejected calls as missed
Voicemail can be cleared in notification
RootBox Settings
General UI
Pie (Paranoid Android)
Low Battery Warning (Pop-up & Sound, Pop-up only, Sound only, Off)
Expanded Desktop
Keyboard
Disable Fullscreen Keyboard (Landscape mode)
Auto keyboard rotation
Option to control cursor in text fields using volume keys
Lockscreen
Lockscreen See Through
Lockscreen Background
Screen Security Features (Unlock options: Quick Unlock, Delay Screen Lock, Menu Unlock, Home Unlock)
Statusbar and Notification Drawer
Breathing SMS
Breathing Missed Call
Display Connected WiFi Network beside Carrier Label
Notification Drawer Shortcuts
Notifications Behaviour (Always Expand, Never Expand, Normal, Old Style)
Notification icon opacity
Power Widget (CM)
Clock
cLock (Chronus)
Sound
Option to disable sound when adjusting volume
Launch Music app on Headset connection
Swap Volume Buttons on Rotation
Hardware Keys
Hardware Keys Remapping
Lockscreen Hardware Keys Remapping
Recommended Installation Steps
Coming from another Custom ROM:
1. Wipe Data/Factory Reset (This does not affect your Internal/External storage)
2. Flash RootBox zip
3. Flash JB GAPPS
4. Wipe Dalvik Cache
5. Reboot
Straight Port From Source
Many Thanks
OSE
Big thanks to Bytecode for ending my misery with Linaro
DroidRzr.com
And of course Tucs
PS the buildbox :)
Download:
#2 x60centenergyx
x60centenergyx
  • 45 posts
  • LocationAtlanta, GA
  • Current Device(s):XT907
Posted 08 August 2013 - 05:52 PM
Can't wait to flash!
#3 somber73
somber73
    Ringmaster
  • 466 posts
  • LocationNY
Posted 08 August 2013 - 06:02 PM
Be aware after some testing hybrid settings are a lil funky working on a fix for tomorrow thanks
#4 lowvolt
lowvolt
  • 478 posts
Posted 08 August 2013 - 06:22 PM
Watching this one
#5 aviwdoowks
aviwdoowks
  • 140 posts
Posted 08 August 2013 - 09:09 PM
There is no navi bar!!!!!!
I tried all the Navi settings- no go.
What is the secret?
I created a custom home toggle as a workaround.
So just Pie control & no navi?
The phone app is good. No great.
BT works!
BT works!
Can I set apps to use the extSD?
Or a 11extsd2internalsd?
Edit Phone shows as a HTC Razr M in Play!!!!!!!!
Thank You!
#6 somber73
somber73
    Ringmaster
  • 466 posts
  • LocationNY
Posted 09 August 2013 - 12:58 AM
What is the secret?
BT works!
BT works!
Thank You!
navbar - working on it
extsd- try it i don't use that option let me know
htc= - a lil bug i gotta work out
#7 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
  • Current Device(s):Pixel 7
Posted 09 August 2013 - 02:53 AM
What is the secret?
BT works!
BT works!
Thank You!
Tim had some of these issues pop up on one of his ports.  Enabling root for adb and apps in dev options seemed to solve the issues.  Turn on the root options, then reboot phone.
  • somber73 likes this
#8 aviwdoowks
aviwdoowks
  • 140 posts
Posted 09 August 2013 - 06:44 AM
No go on su access fix. It was on adb & app already. But after a more use , Maxthon & stock browser it developed the typical 422 freeze up as all other 422 roms I have tried.
#9 somber73
somber73
    Ringmaster
  • 466 posts
  • LocationNY
Posted 09 August 2013 - 11:27 AM
8/09 OP updated.. You MUST do a clean flash otherwise hybrid fix will not stick
Fixed Hybrid setting
Fixed HTC derp
Running Great!! Enjoy!!!
  • timpohladthomas likes this
#10 aviwdoowks
aviwdoowks
  • 140 posts
Posted 09 August 2013 - 03:06 PM
Fixed HTC derp
What do you think was causing both browsers to freeze?
#11 somber73
somber73
    Ringmaster
  • 466 posts
  • LocationNY
Posted 09 August 2013 - 03:52 PM
Not really sure may just be a conflict? Both using the same resource causing the crash? Many  possibilities
#12 somber73
somber73
    Ringmaster
  • 466 posts
  • LocationNY
Posted 09 August 2013 - 04:03 PM
All fixed no need for extra steps :)
#13 thad137
thad137
  • 7 posts
  • Current Device(s):Razr M and Nexus 7
Posted 14 August 2013 - 08:47 AM
Does this have HALO?
#14 lowvolt
lowvolt
  • 478 posts
Posted 14 August 2013 - 09:24 AM
yes. But you have to enable it in root box settings
Sent from my Razr M using Tapatalk 2
  • thad137 likes this
#15 thad137
thad137
  • 7 posts
Posted 16 August 2013 - 01:57 PM
Ok, thank you, but right now I'm trying this Rom:
#16 CamoCustom
CamoCustom
  • 193 posts
Posted 18 August 2013 - 05:58 AM
I have a exchange has stopped on my phone. Is there a way to fix this and get email working?
Sent from my DROID Razr M
#17 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
Posted 18 August 2013 - 01:13 PM
Is the exchangeservices.apk installed?
#18 CamoCustom
CamoCustom
  • 193 posts
Posted 19 August 2013 - 04:14 AM
Yes, not sure why it did that at first, I renamed both the installed Email2.apk and exchange.apk and tried to install both from another source, didnt work, so I deleted those and renamed the Rootbox email and exchange back to normal and rebooted and they worked like they should, so all is well.  One smooth rom, only get a few hangups unlocking screen.
#19 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
Posted 19 August 2013 - 04:22 AM
Interesting, glad that you got it fixed though.  I might have to check this ROM out sometime this week.
#20 CamoCustom
CamoCustom
  • 193 posts
Posted 19 August 2013 - 05:29 AM
i was on illusion for over a week, had some random lag, like things would freeze for 20-30 seconds at a time.
