How I get insane battery life on Razr Maxx HD
12 replies to this topic
#1 mikepahl318
mikepahl318
  • 102 posts
  • LocationUSA
  • Current Device(s):Droid Turbo 64GB, 2013 Nexus 7 32GB
Posted 09 August 2013 - 10:57 AM
My device is running the latest nightly of Cm 10.1 and TWRP. Bootloader obviously unlocked.
On top of CM10.1 I also flashed Crossbreeder
On top of all that I used this script here to odex CM 10.1
I have screen on auto brightness, MSM-DCVS governor, max frequency 1512 MHz, and DEADLINE I/O.
I woke up this morning at 7am and now at 3:30pm i just hit 85% battery life. This thing ZIPS too, no lag. That is with fairly heavy usage as well.
Just wanted to post this in case anyone wanted better than stock battery life on an aftermarket ROM.
  • zooyork0721 and steveo17 like this
#2 zooyork0721
zooyork0721
    All Around Man
  • 979 posts
  • LocationNew York, NY
Posted 09 August 2013 - 11:48 AM
dont have the device :) but im sure people will find this very helpful, thank you
#3 cmh714
Posted 09 August 2013 - 12:20 PM
Now thats an interesting post.....
#4 steveo17
steveo17
  • 66 posts
Posted 12 August 2013 - 10:08 AM
Indeed. Can this be done on 4.3
Sent from my XT926 using Tapatalk HD
#5 cmh714
Posted 12 August 2013 - 10:23 AM
I dont see any reason why it shouldnt work. The script just does the odex/deodex and I dont believe anything has changed. Try a post over in XDA if your too nervous to give it a try.
#6 steveo17
steveo17
  • 66 posts
Posted 12 August 2013 - 10:50 AM
I'm just going to back up and try. I still have to execute it through terminal though right
#7 cmh714
Posted 12 August 2013 - 11:46 AM
Yes, thats what it says. Its a bash script is my guess.
#8 steveo17
steveo17
  • 66 posts
Posted 12 August 2013 - 01:11 PM
Ran it and it seemed to work great. I'll have to see how it helps the battery now
#9 danetbra63
danetbra63
  • 38 posts
  • Locationohio
Posted 14 August 2013 - 05:59 PM
the crossbreeder MOD works better than i expected it to. im slowly trying to figure out the odex
#10 danetbra63
danetbra63
  • 38 posts
  • Locationohio
Posted 14 August 2013 - 07:01 PM
crossbreed and odex run perfect on cm10.2 4.3!
#11 danetbra63
danetbra63
  • 38 posts
  • Locationohio
Posted 15 August 2013 - 02:16 PM
I've tried flashing the odex script.. It flashes but when I go to run it in the terminal it says "dexo not found"
This happens after typing "su"
#12 cmh714
Posted 15 August 2013 - 02:23 PM
Take a look at the script and see where dexo should be. My guess is you need to change into the correct directory before running the script.
#13 danetbra63
danetbra63
  • 38 posts
  • Locationohio
Posted 15 August 2013 - 08:29 PM
How can I uninstall the script though?
