Locked Bootloader 4.1.2 with Safestrap options?
12 replies to this topic
#1 sharklasers
sharklasers
  • 22 posts
Posted 13 August 2013 - 05:35 PM
Hi All,
I am one of the unfortunate ones who can not unlock my bootloader due to the recent update. I have safestrap enabled and I was wondering if anyone can help me with my options. I have tried flashing some of the older roms that are compatible with safestrap (CM10, energy etc) but I am running into problems with the camera working due to my 4.1.2 kernel and the roms being 4.1.1.  Is there a way to get around this and fix the camera for these older versions? OR is there a 4.1.2 based rom that I can flash with safestrap? I read somewhere that deadCalm 1.4 is compatible with safestrap and is 4.1.2 based, but I am getting a status 7 error upon flashing.
Any help would be appreciated.
Thanks!
#2 aviwdoowks
aviwdoowks
  • 140 posts
Posted 13 August 2013 - 05:50 PM
Hi All,
Thanks!
Bad DL?
Did you mount system?
Once on DC you can jump to and from the Avistralia deodexed mod at xda, with your data!
#3 sharklasers
sharklasers
  • 22 posts
Posted 14 August 2013 - 08:38 AM
It is a zip file so I should not have to mount it, just install it correct? I am getting a failure to write the boot.img, I am thinking maybe the partition size created by safestrap is not big enough?
#4 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
  • Current Device(s):Pixel 7
Posted 14 August 2013 - 08:45 AM
With SS, older versions of TWRP, and stock based ROMs, you should mount system.  Most of the stock based ROMs don't have a mount script.
#5 sharklasers
sharklasers
  • 22 posts
Posted 14 August 2013 - 03:30 PM
Alright I mounted the System, Data, Cache, and SDCard, and still got a error (Status 7).... assert failed: write_raw_image("tmp/boot.img").... Any ideas?
#6 Memnoch73
  • 5,016 posts
  • Current Device(s):Pixel 3XL
Posted 14 August 2013 - 04:59 PM
The boot.img is the kernel which it can't install on a locked bootloader. Throw the zip on your PC, open it and pull out that file. Then try the install again.
  • RikRong and aviwdoowks like this
#7 aviwdoowks
aviwdoowks
  • 140 posts
Posted 14 August 2013 - 10:16 PM
I will post a DC system and twrp only that. Wipe dalvik & cache. This is a work around. But a good one. Look for it at my signature @ xda.
Edit you will need wipe data too. I  am not ss savvy. But a twrp restore should work.
#8 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
Posted 15 August 2013 - 02:41 AM
If he's locked up, he won't be able to use stand alone TWRP.
  • aviwdoowks likes this
#9 sharklasers
sharklasers
  • 22 posts
Posted 15 August 2013 - 08:51 AM
I actually found on the DC forum that people were having SS say if failed upon flashing, but upon rebooting the rom would actually load. I tried this and it worked surprisingly.  I havent found anything wrong with the ROM, but I will give it time.
#10 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
Posted 15 August 2013 - 10:29 AM
I was going to suggest that next.  I've seen people report this when they flash Eclipse.
#11 allmightywest
allmightywest
Posted 15 August 2013 - 11:36 AM
I'm new to the forums and been following the locked bootloader issue. I have a dev. model XT907.
Motorola will unlock the bootloader of this model.
I think if you buy a phone, you should be able to do with it as you wish. Hope maybe this helps with the OTA fix.
  • sharklasers likes this
#12 undagullu
undagullu
  • 14 posts
Posted 27 August 2013 - 07:22 AM
has anyone done this succesfully?
#13 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
Posted 27 August 2013 - 07:24 AM
That option is for the Developer Edition.
  • undagullu likes this
