Best Answer themrgoats , 25 September 2013 - 09:33 AM
Finally figured out the problem and a workaround if anyone has this problem as well. The problem is the mediastore component of the OS is not updating properly. The fix is to run a media scanner app from the play store before u plug the phone into the computer to force it to find the new files. I have tried 3 different apps. I'm not sure which works the best. They all may do the trick. If anyone is having this problem just try one of these types of apps until it works. Thanks for the assistance guys. Go to the full post
