Replace headphone jack?
7 replies to this topic
#1 kobe24
kobe24
Posted 23 August 2013 - 08:40 PM
I only receive sound from the left ear. I've tried cleaning the lint multiple times, but I don't think that's it. I think the headphone jack is damaged.
Does anyone know if I can replace just the jack? I really can't find anything on the Razr M :/
Will the headphone jack from a different droid work? Has anyone tried replacing it? Is is soldered?
#2 vic2497
vic2497
    normal droid person
  • 111 posts
  • Current Device(s):DROID RAZR HD
Posted 23 August 2013 - 09:47 PM
There's a big chance that its damaged. You can get a Certified like new replacement phone. I had the same problem so I know how you feel.
#3 kobe24
kobe24
Posted 23 August 2013 - 10:13 PM
Problem is i bought it used. And im using it on tmobile since I unlocked it :/
#4 vic2497
vic2497
    normal droid person
  • 111 posts
Posted 23 August 2013 - 10:14 PM
Ohhh...that is a problem..maybe you can fix by taking it apart and address the problem
#5 Someolddude
Someolddude
  • 426 posts
Posted 24 August 2013 - 06:45 PM
Did you try a different headphone set? Would suck taking your phone apart for nothing.
#6 johnthehillbilly
Posted 24 August 2013 - 07:49 PM
Yes, if you are adept at de-solder and re-solder, you can replace the jack, and yes a jack from another RAZR or HD , or M should work.....
.... you should be having fun ...
#7 kobe24
kobe24
Posted 25 August 2013 - 08:23 PM
Are you sure it requires soldering and desoldering?
#8 livinginkaos
Posted 26 August 2013 - 03:40 AM
Yep
From My S4 Dev Edition
