I am new at this. I was wanting to flash a rom on my razr maxx. I am rooted and have safestrap 3.11. My system is 6.16.215.XT912. 4.0.4 Would like to have JB but dont know which one is best or which would work on my phone. thanks
ICS roms
Posted 28 August 2013 - 08:29 AM
Posted 28 August 2013 - 08:34 AM
You can fully upgrade to JB
There are more ROMs that are fully supported for JB ....
Most (if not all) ICS ROMs are no longer supported....
"... try not, do! or do not! there is no try..."
Posted 28 August 2013 - 10:13 AM
I tried it but couldnt get it to work. It says put it in fastboot mode. I do that and nothing happens. The utility says waiting on phone. I couldnt get it to do anything. Thanks
Posted 28 August 2013 - 10:14 AM
Are you using the usb cable that came with the phone? you cant be using a usb 3.0 port and do you have the latest drivers?
Those are the usual culprits when it cant see the phone.
You can also try to unplug the phone at that point and plug it back in to see if it recognizes it
- johnthehillbilly likes this
Posted 28 August 2013 - 10:45 AM
Well well, I got it in fastboot mode. It wasnt successful and now I cant get it to normal mode. It just goes to the fastboot screen. Have I bricked my phone?
Posted 28 August 2013 - 10:53 AM
From My S4 Dev Edition
Posted 28 August 2013 - 10:55 AM
Hear what the screen says. Invalid Flash Mode(S) (Boot Failure) OA.77 eWWC Info: Size 16g To return to normal-first press power key to power down Device is locked. Status Code:0 Invalid CG otv (cg:system Invalid SP Data. It keeps going back to this screen
Posted 28 August 2013 - 10:56 AM
I dont know what to do now
Posted 28 August 2013 - 10:58 AM
Some have had better luck with it as opposed to the utility
- Memnoch73 likes this
Posted 28 August 2013 - 10:59 AM
As Kaos said, we just need to get something to flash properly. I would try the Utility again, or do as john said and try RSD to flash the phone.
Posted 28 August 2013 - 11:21 AM
Ok I am downloading it now. Hopefully I can get it back going
Posted 28 August 2013 - 11:22 AM
I am on Windows
Posted 28 August 2013 - 11:28 AM
Posted 28 August 2013 - 11:37 AM
I got ot downloaded and cant tell nothing about it. It put all those folders on my desktop. Do you have to burn a disk or something. I dont see anything that says RSD lite. I know I am a beginner
Posted 28 August 2013 - 11:47 AM
Everything should run automatically from there ....
Posted 28 August 2013 - 11:48 AM
you should see an RSD folder where you extracted the utiility
Posted 28 August 2013 - 11:52 AM
I got the utility dowloaded and have it on my desktop. Where do I go from here?
