My razor wouldn't turn on so I did a factory reset, everything went through but when it rebooted it is just stuck in the screen with the triangle on it and the lightning on it. I did everything correct, so is there a different way to do it. The phone has not been dropped, no water damage it just wouldn't turn on one day. Here is a pic of the screen it's stuck on
77.3KB 32 downloadsRazoz maxx hd
Posted 31 August 2013 - 02:55 PM
Posted 31 August 2013 - 03:00 PM
Before any of us can recommend steps to try, we need to know these things....
"... try not, do! or do not! there is no try..."
Posted 31 August 2013 - 03:11 PM
Stock phone. It just went black and wouldn't turn on so I did the factory reset on it. power/volume up/down
Posted 31 August 2013 - 03:29 PM
I really dont know
Posted 31 August 2013 - 03:37 PM
Posted 01 September 2013 - 12:49 PM
This very exact thing happened to me recently. I was Installing and applying a third party page transitional effect. After hitting apply, the program asked me to restart my phone. Upon bootup, It stopped right right where yours has. After many of forum reads and some technical help from Verizon themselves. We came to the conclusion they needed to replace my phone via the warranty...
So i wish you luck in your endeavors...
I had none in mine!
Posted 02 September 2013 - 04:57 AM
Of the 3 warranty replacements, 2 of them had this problem. 2/3 of devices is a bad number.
This is one time I'd actually say that a custom ROM/kernel would probably fix the problem.
Sent from my DROID RAZR MAXX HD
