How To Full Restore On Leak?
10 replies to this topic
#1 atxgurl
atxgurl
  • 69 posts
  • LocationAustin, Texas
Posted 16 June 2012 - 08:21 AM
Can someone please list the process for doing a full restore on a non fastboot leak like 211?
I simply want to take my device back to stock 211 leak.
I am on 211, made some changes and now want to go to back to stock 211.
Posted Image Keep Austin Weird!!
#2 etrorteepe
etrorteepe
    Not a Belieber
  • 221 posts
  • Current Device(s):Nexus 5
Posted 16 June 2012 - 08:46 AM
What changes did you make? I could list off everything but it might not be necessary.
#3 JungleKing76
JungleKing76
  • 446 posts
Posted 16 June 2012 - 08:49 AM
You would have to start over by flashing 181 fastboot, then flash 211 zip all over.
#4 desireaftergod
desireaftergod
  • 536 posts
  • LocationNH
Posted 16 June 2012 - 08:56 AM
What happens if you do a factory reset? :)
#5 tucstwo
  • Google+:tucstwo@gmail.com
Posted 16 June 2012 - 09:04 AM
A factory reset should clear out anything that was done to the system and you should be on a fresh install of .211. If you are asking if you can go back to factory stock as in 6.14.744, that's not doable at the moment if you are on one of the newer leaks.
#6 atxgurl
atxgurl
  • 69 posts
Posted 16 June 2012 - 09:29 AM
Would you mind listing the steps? Do I need to use Unstuck during the process?
#7 atxgurl
atxgurl
  • 69 posts
Posted 16 June 2012 - 09:32 AM
I was under the impression factory reset won't change anything you did to the system. Is that not correct?
#8 EmericanX
EmericanX
    Developer
  • 1,027 posts
  • Twitter:@EmericanX
  • LocationPrince George, VA
Posted 16 June 2012 - 09:39 AM
Here is the all the instructions you may need. I've helped a few through this process so decided to make a thread about it. Hope it helps!
  • atxgurl likes this
#9 EmericanX
EmericanX
    Developer
  • 1,027 posts
Posted 16 June 2012 - 09:41 AM
Btw... this is correct! A factory restore essentially is a data/cache wipe. It will not fix issues with the /system partition.
#10 atxgurl
atxgurl
  • 69 posts
Posted 16 June 2012 - 09:51 AM
Thank you very much!!!
#11 tucstwo
Posted 17 June 2012 - 05:24 AM
Right, what I meant is factory reset doesn't change the system version to the factory version. All it does is erase the data. I guess I worded that kinda weird.
