here are all the tips to charge:
1st way to fix is
1. Press power + vol - and + (make sure its not pluged)
2. after that press vol - and + to get in to the manage part to choose a topic
3. go down to BP tools
4. it should charge if not try the next one
@2nd
1. cut of a printer cable or any cable that contacts to a usb (its a usb)
2. Make sure when you cut the USB u have the usb side still on (not cut) . Now melt the plastic to get the inside wires
there should be 4 wires (black,red,green,and white)
3. cut Green and white (you don't need them)
4. connect red wire to + on your batter and black to - ( on ur battery if you don't know how to open the back please search on Youtube.com)
5. Wait about 2-3 hrs it should be charged .
@last one it work 100% but costs you
Buy a FActory cable for MOTOROLA Xt910 or xt912 (if its any of them )
you can buy one from Black hat team(BHT)
@Other ones to choose if scared
Call to a repair center .(what I did )
but make sure if they can't fix they don't charge you.
Best choose : Factory Cable
Best for free: CHARGER (2nd one)
How To Fix A Dead Battery (Ap Fastboot Low Battery) Tip
DroidRazrpro
, Jun 17 2012 09:31 PM
DEAD BATTERy
4 replies to this topic
Posted 17 June 2012 - 09:31 PM
Posted 18 June 2012 - 04:38 AM
Nice write up!
One thing to mention is that they are "Team Black Hat (TBH)", not "Black Hat team (BHT)" (i think...)
Posted 18 June 2012 - 08:38 AM
OH Sorry ! LOLNice write up!
Posted 20 October 2012 - 01:57 AM
So I used the wrong bat file razer utility and now my droid isnt charged and in ap fast boot ....so do i cut the wires and put the contacts on the battery or??
Posted 20 October 2012 - 06:37 AM
be very careful if you're not good with soldering tiny wires,imho i don't suggest pulling phone apart and jumping battery,i've seen too many guys destroy their phones,i suggest buying adapter or factory cable
- Nitewolf likes this
