hello,
Got a xt905 with australian Telstra firmware bought in hong-kong unlocked.
I verified in the specs that it is a quad band before buying but it appears the 850 and 1900mhz bands are not working, it only pick 900 and 2100mhz networks. So i guess it's blocked in firmware.
I found Telstra and Retail australians versions of firmware to use with RSDlite... will the retail version could remove this limitation ? I will compare the 2 modems files in the .zip tonight to see if the file is different.
I also found a hack for the xt907 using RadioComm software, where you change a memory locations 01 to 00 instead to unlock frequencies. Unfortunately the xt905 have already 00 written there.
I'm a little at loss with motorola (was used to modify sony phones). Can someone please could point me in the right direction ?
Did a lot of reading and my head hurt now, and i didn't found anything :-)
thanks!
