Hi forum friends, I have a problem with my recently purchased motorola X912, it happens that when I buy, I wanted rootear, well you connect and rootie with blade razr program, everything went well, I had my super user icon the desktop, when the next day it disappears root and connecting the phone to usb connect as if not only loads but does not find anything, and I can not do anything for the sole use normally but again nothing to do, I know that I all I can use to see if it connects, I put it into recovery mode and just connect with rsd lite flash sb BP ap mode but flash does not recognize that is connected
Below I detail everything and done:
1-change usb cable usb cable used and tested five other cell and recognize good
2-used several computer testing to see if it was the usb port and nothing
3-install Linux to see if it was windows and nothing
5-downloaded and copied very many rom sd memory installing it for recovery and nothing says I aborted ..
Six factory-refurbished
7-installed rsd lite to flash out there and not detected by putting it in ap
8 - downloaded the razr profits and not recognizing anything either does not work
9 - install and reinstall the motorola driver
By putting the phone in flash sb BP Modol rsd lite recognizes it no problem but do not know what is done in this function.
That could make BP mode flash sb pc recognize me cel. or you could make root of micro sd installing it and if there is some method
the smarphone freezes all the time
Thanx you for help me
