Fastboot Issues
Posted 08 September 2013 - 06:05 PM
Sent from my XT907 using Xparent BlueTapatalk 2
Posted 12 September 2013 - 11:23 AM
So I'm trying to flash using Fastboot, I have done it before.... So if I restart my phone into Fastboot while plugged into my computer it will read that it is connected to USB if I boot into Fastboot then plug my cable in it just says connect USB data cable.... Either way when trying to use Fastboot it will not recognize my device.... Im currently using beanstalk 4.3.07 rom and twrp 2.6.0.0 .... can anyone tell me what is up with my phone... Plez
You're saying the computer won't recognize the device? You need fastboot drivers to get fastboot to work...
Posted 12 September 2013 - 02:17 PM
Posted 12 September 2013 - 02:28 PM
- RikRong likes this
Posted 13 September 2013 - 01:28 AM
The Motorola drivers include the MOT interface (fastboot) drivers ..... reinstall the drivers (get them from here
)... disable any other Motorola programs such as Motorola device manager.... put phone in AP Fastboot .... plug in to computer... it should install automatically then you should be able to fastboot....
According to Mot, that is not true. They seem to imply that all the drivers you need are within the newest version of the device manager:
DEVICE ID AND UNLOCK KEY
Now that you understand the risks associated with unlocking the bootloader, let’s get started!
First, we’ll need to get your device ready to get the device ID and unlock key. You’ll need to do a few things to get this.
- Install the Android SDK.
- Install the latest Motorola USB Drivers.
Next, you will need to get your device ID.
TO GET YOUR DEVICE ID
- Put your device in fastboot mode (press the power button and volume down button at the same time and connect your device to your computer with a USB cable).
- On your computer, open a command prompt or Terminal session.
- Go to the Directory where you installed the Android SDK tools, and type: $ fastboot oem get_unlock_data
Posted 13 September 2013 - 02:03 AM
Posted 14 September 2013 - 04:00 AM
