While I was booted in TWRP, I wiped my external SD card by mistake. Now I have no ZIP to flash, or data to restore. I tried removing the SD card and writing the ZIP file to it and replacing it into the phone, but TWRP will not read it. Do I have any other options to getting my phone restored?
I think I'm in big trouble
Posted 09 September 2013 - 05:38 AM
Posted 09 September 2013 - 05:43 AM
Since you have already cleared your data might as well just restore with the Utility
. Use option 1, then re-root and re-install TWRP then go back to installing your rom again.
Posted 09 September 2013 - 06:07 AM
Thanks, I am downloading the utility..and reading the instructions. It says I must be in fastboot mode. I am in TWRP and can't get it to reboot or anything. Is there anything I can do?
Posted 09 September 2013 - 06:12 AM
Hold all 3 buttons to power phone off. Then hold Power and Vol down to get into fastboot mode.
Posted 09 September 2013 - 08:10 AM
Thanks... got it back to stock. Now I have to remember how to root and all that stuff. lol
Posted 09 September 2013 - 08:11 AM
Its all in the utility you have. Shouldnt be too difficult
- Memnoch73 likes this
Posted 09 September 2013 - 08:54 AM
This is why droidrzr is awesome!
Posted 09 September 2013 - 09:34 AM
Well guys, I thought It was going to be easy. Rerooted, reinstalled TWRP, then booted into TWRP, wiped and tried to install ROM and got an error. Now I have a big blue M otorola in the center of my screen. can't get it to boot back into fastboot. Any ideas?
Posted 09 September 2013 - 09:36 AM
Got it back into fastboot. going to try again.
Posted 09 September 2013 - 09:51 AM
FYI Matts tool uses TWRP 2.5 if you want to use 2.6 you can download it, and put it in the Directory where the other utility files live.
I renamed the twrp.img file to twrp25.img and then dropped in the 2.6 TWRP as twrp.img and used Matts utility. You can also find Tucstwo's REcovery flasher tool, as it has 2.6 TWRP.
Posted 09 September 2013 - 09:57 AM
OK thanks. I got the system reinstalled, now trying to root using option 3, waiting for device forever. What could be the problem? I am connected as media device and can read the sd cards in win 7.
Posted 09 September 2013 - 10:03 AM
Never Mind....got it. and thanks again
- Memnoch73, livinginkaos and cmh714 like this
Posted 09 September 2013 - 10:08 AM
WooHoo !
Sig by
