On a 4.3 ROM I read on xda somebody solved there reboot problem by installing clockworkmod su. I got supersu now that I installed with a zip in recovery but can't get the cwm su to take over. Any ideas?
help changing su.
Someolddude
, Sep 11 2013 07:41 PM
1 reply to this topic
Posted 11 September 2013 - 07:41 PM
Posted 12 September 2013 - 04:41 AM
Figured it out. I downloaded a zip while running 4.3 on Google play. When viewing cwmsu its there. Flashed in recovery. Had to wipe everything and format data and install ROM/gapps then cwmsu zip. After flashing cwmzip had to wipe cash/delvak. Reboot and now using cwmsu. Side note I tried several times and got stuck at bootlogo until I found the proper wipes for installation. What's new so far? I didn't have to use Matt's utility for the first time when stuck! Got right back to recovery every time no problem and eventually was able to successfully reboot. For me this is a good sign as 100% of the time before when using the preinstalled su or supsu zip I could not get back to recovery no mater how much I tried. Can't do a reboot test yet because I have to leave for work soon and its a late night but will be testing that tomorrow or this weekend. Hope this help others.
