[.744 & .748]How To Root Your Droid Razr With 1-Click Method
#61
Posted 23 December 2011 - 06:59 AM
We are moving them around to consolidate.
This will improve the chances of our members getting the prompt and accurate assistance they deserve.
Our members are number one and we will continue to provide you with the best Droid Razr experience possible
#62
Posted 24 December 2011 - 10:47 AM
#63
Posted 26 December 2011 - 12:51 AM
I have a problem. Can't re-root.
Help, please.
This result is after OTA updated. (Gingerbread 2.3.6 stock)
here is the result of execute:
#64
Posted 26 December 2011 - 06:48 AM
I must have did something wrong when I was using TB to uninstall apps. But I ended unrooting using DirtyDroidX direction and re-root. Motocast was back on. I am using TB to freeze before doing any uninstall. So far I am loving the Razr.i could be wrong but i don't think it does... rooting your device is similar to admin privileges or user account control popping up on windows asking for permissions for certain apps to run... maybe you changed something i havent rooted my razr yet so im not exactly familar with this device but the is the grayed out in taskiller? cause mine is grayed out
#65
Posted 26 December 2011 - 08:24 AM
i went ahead and rooted mine.... i didn't set up motocast this time because i use google music i seem to like that better for some reasonI must have did something wrong when I was using TB to uninstall apps. But I ended unrooting using DirtyDroidX direction and re-root. Motocast was back on. I am using TB to freeze before doing any uninstall. So far I am loving the Razr.
#66
Posted 26 December 2011 - 08:27 AM
[Q] Can't re-root on my Razr. Someone please help!
Help, please.
i used this method and worked for me
#67
Posted 28 December 2011 - 08:05 PM
#68
Posted 28 December 2011 - 09:06 PM
#69
Posted 29 December 2011 - 07:28 PM
#70
Posted 31 December 2011 - 07:45 PM
#71
Posted 01 January 2012 - 08:43 PM
#72
Posted 01 January 2012 - 08:45 PM
worked great and was fast. Thanks to Thach for all the help getting this done
Always happy to help. I was afraid that you were going to give up so thanks for sticking in there. Now for the fun stuff right
#73
Posted 05 January 2012 - 08:26 AM
Edit: NVMD.... it went away on its own.
#74
Posted 05 January 2012 - 09:50 AM
That triangle means you are roaming. Go into Wireless/Network settings and turn CDMA roaming to Home and turn Data Roaming off. Data Roaming can get very expensive, very fast.I just did an SBF, took the OTA to .748, rooted with one click, and now I have a flashing triangle by my signal bars. Anyone know how to get rid of it? Added info.: I only did the SBF to get back to a clean slate. My phone was NOT bricked or anything.
#75
Posted 05 January 2012 - 09:53 AM
#76
Posted 10 January 2012 - 01:03 PM
Followed OP, downloaded what was required and I am happily rooted on my white razr.
Now going to fool around my TiBu to lock some of those annoying problems out -
Thanks again all for hopefully increasing my pleasure of this phone.
Eyeing that Moto Razr Maxx that just came out with a weary eye tho...
Double battery life sure would have been nicer on this one.
#77
Posted 12 January 2012 - 06:26 AM
Easy rooting toolkit (v3.0)
created by DooMLoRD
using exploit zergRush (Revolutionary Team)
Credits go to all those involved in making this possible!
---------------------------------------------------------------[*] This script will:
(1) root ur device using latest zergRush exploit (16 Nov)
(2) install Busybox (1.18.4)
(3) install SU files (binary: 3.0.3 and apk: 3.0.6)[*] Before u begin:
(1) make sure u have installed adb drivers for ur device
(2) enable "USB DEBUGGING"
from (Menu\Settings\Applications\Development)
(3) enable "UNKNOWN SOURCES"
from (Menu\Settings\Applications)
(4) [OPTIONAL] increase screen timeout to 10 minutes
(5) connect USB cable to PHONE and then connect to PC
(6) skip "PC Companion Software" prompt on device
CONFIRM ALL THE ABOVE THEN
계속하려면 아무 키나 누르십시오 . . .
--- STARTING ----
--- WAITING FOR DEVICE
adb server is out of date. killing...
--- cleaning
rm failed for *, No such file or directory
--- pushing zergRush"
1125 KB/s (23056 bytes in 0.020s)
--- correcting permissions
--- executing zergRush
[**] Zerg rush - Android 2.2/2.3 local root
[**] © 2011 Revolutionary. All rights reserved.
[**] Parts of code from Gingerbreak, © 2010-2011 The Android Exploid Crew.
[+] Found a GingerBread ! 0x00019118[*] Scooting ...[*] Sending 149 zerglings ...[*] Sending 189 zerglings ...
[-] Hellions with BLUE flames !
--- WAITING FOR DEVICE TO RECONNECT
if it gets stuck over here for a long time then try:
disconnect usb cable and reconnect it
toggle "USB DEBUGGING" (first disable it then enable it)
--- DEVICE FOUND
--- pushing busybox
2142 KB/s (1075144 bytes in 0.490s)
--- remounting /system
mount: permission denied (are you root?)
--- copying busybox to /system/xbin/
/system/xbin/busybox: cannot open for write: Read-only file system
--- correcting ownership
Unable to chmod /system/xbin/busybox: Read-only file system
--- installing busybox
--- pushing SU binary
failed to copy 'files\su' to '/system/bin/su': Read-only file system
Unable to chmod /system/bin/su: Read-only file system
--- correcting symlinks
rm failed for /system/xbin/su, Read-only file system
link failed File exists
--- pushing Superuser app
failed to copy 'files\Superuser.apk' to '/system/app/./Superuser.apk': Read-only
file system
--- cleaning
--- rebooting
ALL DONE!!!
hi can someone help me please.
i'm a noob to rooting..
i purchased a razr that was already rooted.. then got the ota update.
however my version still says 2.3.5 and it is unrooted now.
i've tried all the different root version but still come up with the error as above.
in cmd it has the same errors eg.. read only files etc..
could someone please be kind enough to help me out..
i just want the bloat where gone!
thank you.
#78
Posted 12 January 2012 - 04:54 PM
#79
Posted 18 January 2012 - 01:54 PM
#80
Posted 18 January 2012 - 02:52 PM
Is this method for GSM, CDMA or both ?
I can confirm it works for CDMA, but not sure about GSM. Being that I did not take any part in development or see any mention that it is for GSM aslo, I'd assume not. To be safe, if you are using the GSM version you should probably just refer to our friends at XDA
