i'm sure there is Probam ROM thread for RAZR M, but i can't find it anywhere in this forum?
is it moved, deleted , or what? :
sorry, just curious :
Posted 14 September 2013 - 06:06 AM
Posted 14 September 2013 - 06:43 AM
Sorry no Probam thread here for you. I believe you will find that over at xda.
Posted 20 September 2013 - 07:25 PM
Posted 20 September 2013 - 07:50 PM
So I installed probam for my xt926 and other than slight lag with my launcher it works flawlessly... everything, even my Google movies work. But then it's removed from xda and can't find it here. Anyone care to explain?
Not to get into too much detail, but there were some issues between Pac and Bam. Tim originally ported it, but he pulled it when he heard about the issues. Then the actual Bam "dev" (I use that term loosely) posted the ROM. It was pulled from the 926 forum when the issues were brought up to the moderators. Many of us are working on trying to get all the Bam ROMs pulled off of XDA.
Posted 21 September 2013 - 05:09 AM
Posted 21 September 2013 - 05:44 AM
Thank you for the speedy response and then I as well will not support such a ROM. Moving on to try another.
Not surprisingly, Bam was pretty much like PAC. You should try PAC if you want a similar and more supported experience.
Posted 21 September 2013 - 07:20 AM
from what i heard they are working out their differences and probam is fixing whatever they needed to to be able to post and etc
I hope that's the case, but I haven't heard that. All I've heard were the issues, but I really do hope they're working it out.
Posted 21 September 2013 - 03:06 PM
