[ROM] Droid Concepts | 4.3 | XT907
24 replies to this topic
#1 EmericanX
EmericanX
    Developer
  • 1,027 posts
  • Twitter:@EmericanX
  • LocationPrince George, VA
Posted 14 September 2013 - 07:22 PM
A FULL SOURCE BASED BAG OF TRICKS!
Features:
  • Hardkey rebinding
  • Status bar Clock options
  • LockClock
  • DSP
  • File Manager
  • Focal
  • Apollo
  • Apex launcher
  • Torch
  • Trickster Mod
  • Advanced Options (sensor lights, screen temp, vibration control, sound boost)
  • Lock Screen shortcuts
  • Theme Manager
  • notification drawer styles
  • Quick Settings options
  • custom carrier label
  • expanded desktop
  • notification led control
  • battery light control
  • Music controls
  • camera widget on/off
  • rotation control
  • color and transparent status bar setting
  • etc etc
INSTALL:
  • Download ROM
  • Reboot into recovery
  • Full data/cache wipe
  • Flash DC zip *Gapps are built in
  • Reboot system and Enjoy!
CREDITS:
cphelps76 & davros for their hard undeniable work in this project, Cyanogenmod for the base. Buckmarble for kernel source. Dhaker29 and Hashcode for their relentless Moto support!
SCREEN SHOTS:
coming when I get some extra time to upload.
DOWNLOAD:
DROID-CONCEPTS 4.3 | XT907 | VZW ->
  • karthakon, jamminjon82, BytecodeMe and 1 other like this
#2 brianjamiel747180
brianjamiel747180
  • 100 posts
  • Locationkent
  • Current Device(s):xt907
Posted 14 September 2013 - 11:06 PM
kinda of sketched to try this 4.3 has a lot of bugs for roms right now
61ZM(0)
#3 jamminjon82
jamminjon82
  • 610 posts
  • Twitter:@jamminjon82
  • LocationGloucester, VA
  • Current Device(s):LG G2, Moto X, Kindle Fire 2,Razr M, Nexus 7, Acer A100
Posted 15 September 2013 - 02:39 AM
Most of them are in the past
Sent from my SCH-I535 using Tapatalk 4
#4 crashx2
crashx2
  • 14 posts
Posted 15 September 2013 - 03:10 AM
Has anyone been able to download this file?
#5 cleve22
cleve22
  • Current Device(s):Razr M
Posted 15 September 2013 - 03:24 AM
Heres the link.
  • kyle1329 likes this
#6 EmericanX
EmericanX
    Developer
  • 1,027 posts
Posted 15 September 2013 - 07:17 AM
uploading update now. I'm gonna point the OP to just the directory instead of direct file. That way I don't have to update all links for each new build.
  • jamminjon82 and timpohladthomas like this
#7 Someolddude
Someolddude
  • 426 posts
Posted 15 September 2013 - 10:34 AM
No boot ani not sure if that was your intent. Su not working either no root. Looked cool had some different APS I haven't seen yet.
#8 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
  • Current Device(s):Pixel 7
Posted 15 September 2013 - 05:10 PM
Did you allow root in Dev Options?  I thought the root issue was taken care of on all these 4.3 ROMs?
#9 Someolddude
Someolddude
  • 426 posts
Posted 15 September 2013 - 05:19 PM
Didn't do that. Did open su and didn't ask to install bionary. Tried root checker and said no root. The other 4.3 ROMs just work right off so didn't seem right.
#10 lowvolt
lowvolt
  • 478 posts
Posted 15 September 2013 - 06:46 PM
I see no root either. Could not find a place to allow it in dev options. Very nice looking ROM.
Sent from my Razr M using Tapatalk 4
#11 timpohladthomas
timpohladthomas
    OSE DEVELOPER
  • 1,428 posts
  • Twitter:@timpohladthomas
  • Current Device(s):MOTO X
Posted 15 September 2013 - 06:48 PM
That is a very good idea... Trust me. :-)
#12 lowvolt
lowvolt
  • 478 posts
Posted 15 September 2013 - 07:12 PM
I noticed upon a reboot it hangs at boot logo. Had to restore to my stock back up. Not complaining just informing. Sent from my XT907 using Tapatalk 4
#13 lowvolt
lowvolt
  • 478 posts
Posted 15 September 2013 - 08:55 PM
So by deleting the emulated folder I am now able to reboot. Also flashed super user in recovery and have root.
  • neckchop and RikRong like this
#14 Someolddude
Someolddude
  • 426 posts
Posted 16 September 2013 - 04:41 AM
So by deleting the emulated folder I am now able to reboot. Also flashed super user in recovery and have root. Sent from my Razr M using Tapatalk 4
I've tried deleting that folder before and it doesn't delete. I think it may have been you who mentioned doing that for another ROM you were having reboot problems with before. Didn't work for me . Says device or resource busy. All the contents delete but the emulated folder stays.
#15 lowvolt
lowvolt
  • 478 posts
Posted 16 September 2013 - 08:52 AM
Does anyone know what would cause phone idle to consume 24% battery? I have NFC frozen. Phone idle is at 9% now but earlier it was 24%. I will continue to use phone as normal and report back. Also email keeps force closing upon notification. If I clear the notification and open the app I can read the email. Thoughts on this? Clear cache? Edit: is there a way to get the dialer keypad to show on 800 numbers? Sent from my Razr M using Tapatalk 4
#16 Someolddude
Someolddude
  • 426 posts
Posted 16 September 2013 - 02:19 PM
I haven't froze anything and its at 6% for 8hrs of use. Were you in a bad spot and your phone was searching for WiFi? Happened to me one time at the vet. Killed my bat fast and noticed my phone getting hot. Turned off my auto search WiFi stuff and took care of that.
  • lowvolt likes this
#17 lowvolt
lowvolt
  • 478 posts
Posted 16 September 2013 - 03:35 PM
No. In fact I was at home on WiFi and had just taken it off the charger an hour or so before. Maybe it hadn't calibrated.
#18 lowvolt
lowvolt
  • 478 posts
Posted 16 September 2013 - 04:25 PM
Is anyone else having issues with email?
#19 chuck8145
chuck8145
  • Locationkentucky
  • Current Device(s):razr
Posted 17 September 2013 - 12:39 PM
best 4.3 that i have installed this far.works great thanks.
#20 lowvolt
lowvolt
  • 478 posts
Posted 17 September 2013 - 01:10 PM
do you use email? Any issues?
