RAZR XT912 ENCRYPTION UNSUCCESSFUL Help!
1 reply to this topic
#1 tachirito23
tachirito23
  • Current Device(s):Motorola RAZR XT912
Posted 15 September 2013 - 02:11 PM
Sorry if I do not understand.I do not speak the lenguage.
I have my Razr xt912 and I want to install a custom roms, recovery, etc, etc. First I install the safetrap and all are fine, but after that I install the Clock work mode...
I select Install recovery and Reboot system and whe it turn on only appear's on my screen Encryption Unsuccessfull and the option of Reset the phone.
I don't know what I can do, please help me...
#2 johnthehillbilly
Posted 15 September 2013 - 02:17 PM
Ok the problem is you are trying to install cwm .... safe strap is all you need.. . Cwm(clockworkmod) is not compatible with the RAZR xt912 ..... You need to use this utility
and go back to stock (option 1) ... then root... then install safestrap..... HD tappin' .... hillbilly style!!
  • rickw likes this
