Rooted Safestrap issue.
2 replies to this topic
#1 SYSo
SYSo
    Well, I think I know what I'm doing.
  • 23 posts
  • Twitter:@manisrobby
  • Current Device(s):Droid Razr XT912
Posted 17 September 2013 - 07:55 AM
Hey, I will get right to my issue. So I was trying to make space on my phone and I thought I moved the safestrap folder to my external sd card (sdcard-ext) I guess I moved the wrong thing or something becuase even when I remove my sd card from my phone when I boot my phone I am still able to get to safestrap. Now heres the wierd part if I try to wipe my internal storage on my phone this is the message I get. "unable to locate volume for device." Anyone know how to fix this? Also if anyone has a stock rom for the xt912 razr please post I need it. Thank you for all of your help!
      ___           ___           ___           ___
     /\  \         |\__\         /\  \         /\  \
  _\:\~\ \  \      |:|__|__   _\:\~\ \  \   /:/  \:\  \
 /\ \:\ \ \__\     /::::\__\ /\ \:\ \ \__\ /:/__/ \:\__\
 \:\ \:\ \/__/    /:/~~/~    \:\ \:\ \/__/ \:\  \ /:/  /
  \:\ \:\__\     /:/  /       \:\ \:\__\    \:\  /:/  /
   \:\/:/  /     \/__/         \:\/:/  /     \:\/:/  /
     \/__/                       \/__/         \/__/
#2 johnthehillbilly
Posted 17 September 2013 - 08:01 AM
Even moving the safestrap folder the phone should always be able to access safestrap prior to full boot up.... the safestrap folder containes your slots that you have created..... it must be on the internal storage for you to based able to boot into any ROM other than stock.....
As far as a stock ROM , are you looking for one that you can flash to a ROM slot in safestrap? .... or are you looking to restore complete stock to your phone?.
#3 SYSo
SYSo
  • 23 posts
Posted 17 September 2013 - 04:51 PM
Either one would be fine at this point. RIght now my phone only has a little white light showing when I plug it into my computer and When I plug it into a wall charger I can only get up to ss and when I click to get into safestrap the screen goes black.
      ___           ___           ___           ___
     \/__/                       \/__/         \/__/
